Question about Apex Digital AT2708S 27" TV
No Picture My screen is white with vertical lines accross. Sound ok There was a beautiful picture, great color, then I had a problem with TIVO loosing its menu.
  • slimjime Nov 06, 2007
    I am a Senior Citizen no funds available, The set is 5 years old
    Problem Solver:
  • 20 Answers
If when you press the volume or channel up or down button you get no OSD, that's is no channel number or volume up bars, have some one check the set for either a defective video out IC or a defective picture tube, or a bad cap in the power supply. Set should be serviced by a TV repair person.
Good day!
Posted on Nov 06, 2007
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
My picture shrinks
resolder the vertical deflection i.c. also replace elecrolytic capacitor in the vertical circuit.
Sep 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
Insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Panasonic TV - no picture, but sound is ok
it is due to vertical section failure.
  • before you start any work reduce brightness to avoid crt burn.
  • please check some loose contact or loose connector.
  • check supply to vertical section
  • check parts in vertical output section
  • check vertical ic.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Apex Digital AT2708S 27" TV Logo
83 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
