My car overheats every time I drive it. I had replaced a lot of parts like the water pump, timing chain, knock sensor, thermostat (2X) and radiator (2X)also recently had the heads replaced as well. it seems like the fan doesn't kick on until right before the gauge is in the red and the coolant is boiling. turning the heat on does nothing and at times the heat stops working as well. the ac working fine though. This has been going on for a year now!!! i have been told it could be cooling sensor, tempeture control. I am at a loss. Please Help
It might be the heater core. If it does not help with the cooling and does not give out much heat it may be clogged.
Testimonial: "I do have heat except for when the car overheats. the book says turn the heat on onto the floor. it works for a few secs then its just air. It still blows air just not hot. and the heat works fine until the engine gets too hot."
For car running hot and overheating issues, I suggest to you go
through this help links. Click this link below and go through the
troubleshooting procedure to take care of the problems: ----
temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge keeps fluctuating up and
down close to red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and
troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Temperature gauge does not move and no heat
when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
This details will help.Thanks.
