Question about Nikon D200 Digital Camera with 18-200mm Lens
Format problems. every time I try to format the
Format problems with D200 Nikon. every time I try to format the card the camera does so and "says" Done, but then it tells me to format the card when I try to use it.
  • 146 Answers
Sound like a damaged card, can you try another card in the camera?
My D80 did this once and the card would work in other cameras but not the D80 again.
Posted on Jul 03, 2009
When I put a card inside my camera D200, the massage displays and blinking "For", whats the issue and how can i fix it
Sounds like a format error. Try formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 10, 2010 | Nikon D200 Body Only Digital Camera
My Nikon D2oo is not working with Extreme 111 Compact flash cards that I just had the camera Format. There is an burn oder coming from either the camera or card.Wanting to put card not formatted with...
Hello, and thanks for using FixYa.
Please if the card contains any important pictures, connect it to a computer and copy them to the computer if they are not backed up. Then put the card in the camera and format the card in the camera, then you can connect it back to the computer, put those pictures in there and then the card back into the camera if that is what you wanted to do.
Note that the camera might not show your pictures, unless they are named the same way as original pictures taken with the camera.
Oct 22, 2010 | Nikon D200 Body Only Digital Camera
Nikon D200 - problems formatting card
To use the two format buttons:
Press the "trashcan" format button and hold it. Then press the "mode" format button and hold it. Hold for approx 3~4 seconds. The screen will go blank and display "For" and the number of shots taken on the card.
Release both buttons. Then press the "trashcan" again followed by the format button. The screen will go back to normal, except the number of shots indicator, it will display "For". In a few seconds, your card will be formatted.
Although this may not solve your problem, you may have bad CF Card.
This is normal. Happens all the time.
Try another card. It should format fine. If it doesnt, take your camera to an authorized dealer/repair shop for maint.
Jun 27, 2009 | Nikon D200 Digital Camera
Can not format card for Nikon d200
Is you camera plugged into you computer. If so, you cannot format the card from the camera, unless it is unplugged. This just happened to me (I was about to look for a bent pin). Unplugging solved the problem.
Sep 26, 2008 | Nikon D200 Body Only Digital Camera
D-200 not recognizing flash card
try to plug the card to a card reader, connect to a computer and check if it can still detect the card. If it does, check if your pix are still there, if none, reformat the card using the computer
May 05, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 and microdrive
I assume by "microdrive" you mean the compact flash card - right? Not all compact flash cards will word with the D200 - what is the brand of each of the flash cards you have (and are they all the same-purchased at the same time)?
Nov 02, 2007 | Nikon D200 Digital Camera with 18-200mm...
Exposure button not working
Have you done the firmware update? If not the update is available here: CLICK HERE FOR MACINTOSH or CLICK HERE FOR PC.
If that didn't solve your issue, you may have to go to an authorized Nikon dealer to have the camera reset. The internal battery cannot be serviced by untrained persons. I would also suggest that going forward, you carry your camera inside your coat when you're outside in cold weather, since electronics are easily damaged (especially software) by frost and / or water vapor which can very easily damage parts of your camera (hardware and software) in any weather.
Oct 20, 2007 | Nikon D200 Body Only Digital Camera
Nikon D200 Digital Camera with 18-200mm Lens Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
