I have lost the owners manual and do not how to unclog the machine. When I push the pump trigger, it seems like the valves inside are clogged. How do I unclog the lines. Should I use varsol? Seems like the liquid left from last year hardened in the lines.....
Hello, i just finished a successful repair. i did have to take it apart, and there were springs and ss balls(at fog liquid pickup end that i unscrewed to give easy access to blocked pipe) and such so work where parts won't be easily lost and pay attention during disassembly. The problem with mine(several years old) was blockage in the metal line(pipe) that carries the fogger liquid. i used carborator cleaner and a compressor hose with low pressure. i sprayed in the cleaner and then put air pressure each way back and forth till it eventually yet suddenly cleared out then allowed unobstructed passage. then flushed it to clean it well. BE CAREFUL, it can suddenly spray the cleaner out, safety glasses saved me from a bad accident but my face and lips were stinging from the cleaner, and that was with the end facing away from me(but into a bucket and it bounced back at me). Anyway, reassembly took a bit but now it fogs great again. Mine might be a different manufacturer(burgess) but most likely the same basic scenario. Best wishes
i am looking for the operating instructions for the Fountainhead/Burgess Prod Black Flag Propane...
(More)
i am looking for the operating instructions for the Fountainhead/Burgess Prod Black Flag Propane Fogger
When sprayer is pump no fog comes out. I took apart fogger and small brass valve seems to be...
(More)
When sprayer is pump no fog comes out. I took apart fogger and small brass valve seems to be broken. Is there a place to get a new part?
