Sony FD Trinitron KV-32HV600 32" TV Logo
Posted on Nov 06, 2007
No Video or Sound - Red Stand By Light Blinks 6 Times
I have a Sony KV-32hv600 and the video and audio are inoperative. The red stand-by light blinks 6 times. I am assuming the blinking red stand by light is indicating some type of service code. Does anyone know what type of service problem the 6 blinks indicate?
Thanks for taking the time to read my post and consider my question.
  • 1 more comment
  • Fire4Effect Nov 07, 2007
    My book says the same thing, but I did find a site that listed what the blinking codes mean.
    # Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
    BTW, I left the TV unplugged overnight and it worked fine when I plugged it in later today. I just tried to turn it on again and the screen is black and the 6 red blinks have returned.
  • mycklb Mar 08, 2008
    I have the same problem....even came back on after a while, but now just the 6 blinks on standby. Has anyone fixed this problem. Thanks.
  • whtt06 Nov 27, 2008
    tv doesn't turn on, standby light blinks.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 06, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1636
Points
5
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
2answers
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Sony kp-57ws510 timer/stand by light blinks 6 times. no picture or sound. Whats wrong?
the best moment to starting is the VIDEO DETECTOR,+Audio i-f and by splitting your can troubleshooting and fix it. see the b.diagram attached.
My sony kv-32hv600 has a red Stand By light blinking 6 times and then it pauses and blinks 6 more times. Is there any way I can reset it so that I can use the TV again. There is no picture or sound coming...
No the blinking lights are an error code with an issue and that protects the TV from further damage.
I believe that is a power supply board failure code. Time for repair! Sorry! Take it in for service or you may try to repair it yourself.
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
Sony KV-32HV600 won't turn on.
If the blink repeats the same number of times (up to 6 or 7) between pauses, the number of blinks is a trouble code. Determine that number (count), then search this site and the web for your TV model and that code. Also look on the rear of the set for the chassis number, and search on that keyword.
1helpful
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
