Question about HP Pavilion dv9000t Notebook
When I shut down or restart my laptop, the lights on the keyboard will come on for about 10-15 seconds and turn off and then repeat until I push the power button. Why won't my laptop turn on the first time?
Factory reset my Toshiba a6
Shut down and restart your Toshiba laptop by pressing the power button. Immediately and repeatedly press the F12 key on your keyboard until the Boot Menu screen appears. Using your laptop's arrow keys, select "HDD Recovery" and press enter. From here, you will be asked if you want to proceed with the recovery. http://electronicshelponline.blogspot.com/
Nov 06, 2016 | Toshiba Computers & Internet
Toshiba Satellite L505D-S5983 black screen
Hold the power button down until the unit shuts off, wait 10 seconds then turn it on again.
Upon restarting, make sure to choose Start Normally if the startup failure menu comes up.
Apr 13, 2014 | Toshiba Satellite Computers & Internet
Cursor frozen
(1) You can try ctrl-alt-del buttons on keyboard press all @ same time select (use arrow keys) to move to restart press enter on keyboard or (2) hold power button for 6 seconds it will shut down then wait 3 seconds push start button as normal should re-boot
Jan 01, 2014 | Toshiba Satellite Computers & Internet
Frozen cursor
Hope this helps
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
How to reboot compaq mini
Reboot is another
name for restart, so
just click into the Start
menu then shut down
then choose restart. If
you are unable to do
that since if the laptop
is frozen push and hold
the power button in for
at least 10 seconds or
until the computer
turns off, then push the
power button again to
turn it back on. This
should only be done if
anything else.
Ok
Jul 25, 2011 | Compaq Computers & Internet
Startup computer and all of desktop is there. then the screen goes to blue and then back to normal. This continues to repeat over and over. Any ideas? Warren
You may need to restart the PRAM and NVRAM:
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Nov 13, 2010 | Apple 24" iMac Desktop
Inspiron 1525 keyboard/touchpad locked.
Press ctrl alt del together then try to enter your password. If it doesn't work. restart your computer by holding down the power button for 10 seconds or until the computer turns off. Restart and tap F8 repeatedly as soon as the light comes on. Choose 'Last known good configuration' using your keyboard. Then press enter. Try if you can login now.
Dec 15, 2008 | Dell F3534 Touchpad
How do i remove the back off a sony vaio to replace usb ports? i have took all the screws out but do not want to put to much pressure on as do not want to break it! (Repairing it for a friend)
You cannot easily replace the usb ports as they are soldered as part of the motherboard. If the ports are not working then go as follows and attempt to reset them
I'm going to assume that you're running XP (home or pro). . This is the sequence to use
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Dec 09, 2008 | Sony VAIO PCG-K23 Notebook
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
2. Click Hardware
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
HP Pavilion dv9000t Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
