Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have the same problem
The drum slowly fills when the unit is off. I suspect that the valve assembly is not shutting completely, but I am not sure.
  • 11,896 Answers
I agree. The valve isn't closing
Posted on Jun 27, 2009
Maytag Ensignia top loading washer water hammers and fills slowly.
Check the water flow coming out of your water valves on the wall. Once in awhile a faucet washer comes loose in the valve causing "flutter". Check the flow through the hoses before they get to the washer.
Sep 24, 2017 | Maytag Washing Machines
My washing machine drains all the water at the end of the wash, but then slowly starts to fill back up. What is causing this to happen?
Hello cowmeag - From what you are describing, there are two possibilities: the valve assembly may not be seating properly or the Main Control board is sending voltage to the valves. If the valves do not seat properly, water will seep paste the valves and gradually fill the unit. I would recommend unplugging the unit. Wait approximately ten minutes and restart unit. If it still slowly fills, more than likely you water valve will need replacing. Otherwise, the dishwasher has a possible Main Control board failure.
Mar 08, 2013 | Frigidaire Affinity ATF7000E Front Load...
Opened up the freezer to find a spray of ice over everything. Assumed it was water from the icemaker so shut it off. Any suggestions? Thanks in advance, bob.
Suspect ice delivery tube froze slowly causing water to compress and spray. Delivery tubes can naturally freeze. Altho it more often happens because the fill valve does not shut down 100%. Small amounts of water are pushed via line pressure and slowly restrict the delivery tube. Fill Valve 4389178 Est $85 -110.
Ric
Mar 09, 2010 | KitchenAid KSRG22FK Side by Side...
Water in drum between washes
the problem is you inlet water valve. they will sometimes drip water into the unit just like a sink faucet that doesnt shut off.
when the valve gets residues in it, it wont always shut off and can fill your unit with water over time.
it is best to shut off the faucets to the washer when you are not using it and then get the valve replaced.
you could have a flood if it drips more then the unit can hold.
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3t Frontloader Fills Up With Water After Cycle
inlet valves have possibly gotten dirt in them and need replaced . quick fix , is turn the water valves off behind the machine
Nov 07, 2017 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Water does not shut off. Water flows constantly
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Aug 29, 2009 | GE WBVH6240F Front Load Washer
Drum fills with water slowly when not in use
tis is a bad water inlet valve - it is not shutting off completely. Hope this helps!
Jun 26, 2009 | LG WM1812C Front Load Washer
Dishwasher slowly fills with water
Greg, at this link you can download available manuals for your unit.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GU1100&siteCd=WHRCOM
Good luck with your repair.
Please take the time to rate this solution.
Jan 29, 2009 | Dishwashers
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
83 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
