Question about HP OfficeJet 6210 All-In-One InkJet Printer
Everything works but the scanning, it says i need to install or run a software for this feature! please help!
  • 221 Answers
Hello, the software to use for the HP scanners is called "HP Image Zone" and can be found in your install cd or in HP's website.
Hope this helps
Posted on Jun 27, 2009
How to scan using a hp deskjet F2235 printer???please help me...
In order to use the scanning feature you would need to install the drivers and other software that comes with the printer. If you haven't install either, please visit http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3571755
and download the drivers for your operating system. It should come with some sort of imaging suite that would allow you to scan documents and save them to the computer.
Jun 21, 2011 | HP Deskjet F2210 InkJet Printer
My hp 6210 says in order to scan i need to install or run device software feature. This feature has worked in the past, but has not worked since I moved the printer. It is hooked up to my pc and the...
Before you do anything, i would suggest you to uninstall the complete printer's software and to reinstall it after running a registry cleaning (restart your system before you reinstall it).
If the problem still persists, please let me know. We'll need another measure.
Good luck.
Thanks for using FixYa.
Jun 18, 2010 | HP OfficeJet 6210 All-In-One InkJet...
When i try to scan, it says need to install or run device software for feature
if your printer came whith a disc make sure you install everything on the disc to your computer or if you have already done that if the disc had a scanning program try using that
May 16, 2010 | HP PSC 1610v All-in-One Printer
HP PSC 2175xi prints, but won't scan
you most likely require the twain driver that should work over usb - you should be able to download that from the hp website.
Jun 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
Will not let me scan documents
install the software first and then you will be able to scan its just that the scan options are not getting detected from the software on the computer that assigns the scanning options.
IF the software is installed then open hp solution centre and point to settings.Then point to scan settings and click on scan to setup and move all the items on the left to the right by selecting each one and pressing the right arrow button and click on ok and now check you will be able to scan
Jun 15, 2009 | HP Officejet 7210 All-In-One InkJet...
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
No scan options msg when I try to scan
I need to find the scanning software for hp 7310. It use to work, I had to reload everything and now I cannot get it to work
Nov 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP PSC 2355 all-in-one printer not scanning
You need to start the HP software that's installed on your PC.
In Win XP, go to Start menu, look down the list of installed programs, and click on HP Director to start it up. Your scanner should work now, either from the scan buttons on the printer, or from the scan options within HP Director.
Nov 11, 2008 | HP PSC 2355 All-In-One InkJet Printer
Scanning capabilities are gone
Hey,
the drivers and software are available on the hp page, let me get you the correct ones, which windows are you using?
Thanks,
Ekse
Sep 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
How to get the scanner working
Did you d/l the software program or just the drivers?
If you downloaded the softwared along with the drivers, then you should have a program that you should have installed that you can start up and then run different options from your computer.
The file that you should have downloaded should have been a 163 MB file. The description of the file is:
The Full Feature Software solution supplies full access to the many features of the All-in-One device and is intended for Users who want more than just a basic print and scan driver.
Here is the link to HP's Site for the d/l:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-1&lc=en&cc=nz&dlc=en&product=390315&os=2093&lang=en
Good luck,
Hope this helps.
If I have helped you with your question, please remember to leave a feedback and or rating for me.
Thanks
Mac
Feb 14, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
