Question about Lucien Piccard 26024 Wrist Watch
Watch band resizing
I have a Kreisler watch band that needs to be resized, but I don't have the special tool for it and none of the tutorials I've found deal with this kind of watch band.
  • 183 Answers
This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out.
* I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
Posted on Sep 20, 2009
How to resize watch bands with screws.
Yes you do. There is a screw head at the top and the rest is pin. You need a set of jewelers screwdrivers.
http://www.girr.org/girr/tips/tips6/tool_tips/screwdriver_set_small.jpg
Nov 06, 2017 | Bulova Watches
Tip
How to resize a (Casio) watch band
Because there are a lot of questions about resizing watch bands, I thought I'd add a tip how to do it. Roughly two types of links are used with Casio watches, so I've added two how-to video's:
on Mar 26, 2015 | Casio Watches
Montres Carlo. How can I shorten the band?
WATCH BAND ADJUSTMENT / RESIZE - HOW TO - YouTube
? 5:51
https://www.youtube.com/watch?v=N42D4lwD5Ok
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
How to Resize / Adjust a Watch Band - YouTube
? 6:39
https://www.youtube.com/watch?v=o3NfebIjLlU
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
Jan 19, 2016 | Watches
How to remove watchband on timex atlantis 100
On this link you can see how to resize and remove the watch band.
You need some tools.
Resize your Watch Band and Remove Links with Basic Tools
Jul 21, 2014 | Timex Atlantis 100 77517 Wrist Watch
How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    I need to resize a watch band for my mother. It is a stretch band with links
    I suggest you take it to a watch shop (decide how much shorter you need it before you go - or take mother and watch to the shop).
    It is very quickly done when you know what you are doing and have the tools!
    Feb 20, 2010 | Watches
    Resize DKNY 1035 Wrist Watch band
    Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
    Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
    Jan 10, 2010 | Watches
    How can I resize a citizen watch with an expandable band? It's a little too big. The owner's manual doesn't tell. Thank you-
    If you look carefully on the inner side of expandable bands, there's usually the removable links of the band near one or both ends of the band.
    These usually have arrows indicating which direction the locking pin/tab slides to unlock and allow removal.
    If you're careful, you can unlock them and remove one or two by using a small screwdriver. A very inexpensive alternative is to find a local watch repair shop and have them resize if for you while you wait. They've got the mini-tools and it's usually very reasonable (around here, there's a couple chain grocery stores that have watch repair kiosks inside..great alternative and cheap).
    Nov 17, 2009 | Citizen Silhouette Eco Drive Gold Tone...
    Trouble sizing Fossil Watch CH-2506
    Those arrows inside of the watch band are showing direction for pins or clips to come out. If you have two arrows in opposite directions on one link, that means there are two pins or clips and each one must be extracted from arrow pointing side.
    If there is only one arrow on the link- there is only one clip or pin and must be extracted the arrow pointing way.
    Some watch bands are held together by very specificly made clips or pins. In this case you will need a special tool to extract them.
    Jan 02, 2009 | Fossil Chronograph Urban White Dial CH2506...
    Wrist Band Resizing
    I did find a solution. I used a push pin tack to push the pins out. Not easy but it did work.
    Jun 16, 2007 | Field and Stream F112GUBS Wrist Watch
    Lucien Piccard 26024 Wrist Watch Logo
    1,282 people viewed this question
    Top Lucien Piccard Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Lucien Piccard Watch Expert? Answer questions, earn points and help others
