Question about Toshiba Portege 7200CT Notebook
SD Memory Card for Toshiba Camileo HD Camcorder. Can U tell me exactly what I should ask for in store. No store near me stocks Toshiba, so I need to be able to ask for the type / size of card for camera. From Patrick in Dublin
  • Toshiba Master
  • 4,806 Answers
Hi Patrick,
It's up to you mate, you can get either 2GB, 4GB or 8GB memory cards which will work with that camcorder.
Regards
Posted on Jun 27, 2009
I have a DXG 5B1 HD and need to replace the card. What specific card is compatable?
As per this page:
DXG USA DXG 5B1V HD DXG Sportster 1080p HD Underwater Camcorder
SD Card (Up to SDHC 16GB Class6)
This is probably one of the best you can buy:
SanDisk Ultra 16GB SDHC Class 6 Flash Memory Card Speed Up To 30MB SDSDH...
If you don't need 16GB, you can buy cheaper cards with less storage space.
Jan 29, 2015 | DXG 5B1V HD Sportster 1080p HD Underwater...
CAMERA SHOWS THIS CARD CANNOT RECORD IN VIDEO MODE. HOW DO I FIX IT?
I see two possibilities. Fortunately they have the same solution.
What type and speed memory card are you trying to use? Is the card compatible with the camcorder? Since you didn't specify the model of your camcorder I can't tell you what type of card you need to use, but if the camcorder is designed to use SD cards and you're trying to use an SDHC card then it won't work.
The second possibility is that your card isn't fast enough to record video. There's a lot of data involved in a video clip, and not all memory cards are fast enough to handle it. The situation is much worse with HD video. Again, without knowing the model of your camera I can't tell you how fast a memory card you need.
Apr 20, 2012 | Panasonic Video Cameras
Camileo s30 not charging
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Mar 15, 2012 | Toshiba Camileo S30 HD Camcorder -...
Toshiba Camileo H30 only records onto built in memory. When I put in an SD card, gives an error message (a yellow exclamation point inside a folder). Please help. The camera is brand new. Regards, AL
The first suggestion would be to check if the SD card is the correct one, and if it is correctly installed. On my Hi-Def Hard Drive Camcorder, when properly installed, the SD card looks like it's "up-side-down" - with the little metal sensors upward. It is easy to accidentally put it in - what seems to me is "right-side-up". Then I see an error message and need to flip it over.
You might also check to see if the metal sensors on the SD card are all intact. Sometimes one of the little metal sensors are slightly out of line or maybe bent.
May 15, 2011 | Toshiba Camileo H30 Hard Drive Camcorder
Ny Toshiba Camileo P10 is reading "card locked"
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 19, 2011 | Toshiba Video Cameras
Camilio s10 wont clear card locked
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Jan 22, 2011 | Toshiba Camileo X100 High Definition...
Toshiba Portege 7200CT Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
