Question about RCA F27442 27" TV
RCA TV model #HD61lpw165 has no sound.Everything else works fine.Have already tryed the unpluging the TV resolution,did not work.
silly girl
  • 513 Answers
SOURCE: RCA F27665 27
If still under warranty or if you have no electronic repair experience take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. If the TV fell recently the following might apply to you: 1. Cracked circuit board very possible, try changing it. There is a very good chance that the circuit board has some broken traces. You would not be able to see this by eye unless this was very bad. The way to find this, is to troubleshoot the set on the bench to determine which stages are not working correctly, and pursue from there to find where the signal paths, or missing voltages are sourced from. If the set fell, there is also a good chance that the CRT is damaged inside. These tubes are extremely sensitive to being hit or jarred abruptly. I have seen a TV set banged against the side of a door frame while being moved, thus causing damage to the shadowmask of the tube. 2. Check for A/V input circuit board not seated all the way. If this board comes loose, your video will disappear. In case no violence disturbed you set: 1. It is very possible that something is changed in the user setup that is causing the no useable input condition. Check the owners manual and verify the proper user settings, especially the Tv-Guide settings for use with or without cable box or vcr if tv has that feature. 2. this is a fix for a similar set, might apply to yours: Try resoldering all 3 legs of q2300 the if amp transistor and usually pins 1-8 of u2300 the IF ic. This usually takes awhile because there are sometimes a lot of poor joints in that area of the board, look it over very carefully it usually fixes these sets. Good luck, and please try not to take any chances
Posted on Jan 29, 2006
  • 275 Answers
SOURCE: rca truflat with green tinted picture?
Just because a machine has failed, there is no cause for you to call it a stupid TV. And as it is only 6 months old, why not take it to the Company service Centre? There must be warranty.
Posted on Apr 02, 2007
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
techman
  • 3130 Answers
SOURCE: RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Posted on Oct 16, 2007
SOURCE: Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Posted on May 15, 2008
Lost picture but sound is on
almost certain this is a lamp problem, bulbs blow up
if you remove the lamp you can see if the bulb is broken inside.
Jul 19, 2010 | RCA HD61LPW165 61" Projection HDTV
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
P4673owk RCA tv. It works fine. I played a dvd
have you tried unplugging it from the power outlet and letting it reset?
Aug 02, 2009 | Televison & Video
No picture no sound
High voltage Trippler is bad or shorted tube or need to replace FET ,startup Kit it has 16pin ic/ 4capacitors /resistors /everything you need to repair that circuit.So your tv is 15yrs old cost of replacing tubes 300.00 per tube.plus labor 190.00 and up ?
Dec 18, 2008 | RCA P52926 52" Rear Projection Television
My rca television works fine exept for the sound
There is a switch on the back of the TV that toggles between the built in speakers or the external speakers. Try flipping it and see what happens.
Jul 21, 2008 | RCA MM36100 36" TV
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA F27442 27" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
