Question about Toshiba Satellite 15" Flat Panel LCD Monitor
My light come on but the screen is blank
I have a Toshiba Satellite 1415 my screen light come on but the screen is blank
mewms_14904
  • 1027 Answers
SOURCE: Modem and Audio trouble with satellite 1415-s173
Link to modem driver
Link to 2 pages of driver downloads for your toshiba
Posted on May 07, 2008
frenzy19
  • 258 Answers
SOURCE: Toshiba Satellite Laptop - blank screen at start-up
press F8 or F10 during startup
Posted on Dec 17, 2008
  • 11 Answers
SOURCE: Power Saver does not open, Toshiba Satellite 1415-S-173
While on the Desktop RIGHT CLICK the mouse and LEFT CLICK on PROPERTIES. LEFT CLICK on the SCREEN SAVER tab. Then LEFT CLICK on the POWER BUTTON. From here you can change your power options.
Posted on Mar 05, 2009
  • 3278 Answers
SOURCE: Is there a wireless card in the toshiba satellite 1415-s173?
Unfortunately, Gerald, this laptop does not come standard with a wireless card, but has an internal Ethernet card to connect to the network via an Ethernet cable. There are 2 ports with similar shape - one is a modem port for dialup and the other, larger port is for the Ethernet cable.
It also does not appear to have a USB port, so you would not be able to use an external USB wireless card.
Not the answer you were looking for, but hope this info helps.
Posted on Sep 19, 2009
Geekman
  • 32281 Answers
SOURCE: toshiba satellite m305D screen blanks out after
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first
Posted on Oct 16, 2009
I am trying to figure out how to boot from a usb drive on my toshiba satellite 1415-s105
1. Press F12 key while the Toshiba splash screen is on, this will bring up the boot options menu.
2. Immediately after pressing the power-on button, press the U key.
For more information on boot options for Toshiba:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Jul 21, 2011 | Toshiba Satellite 1415-S105 Notebook
I need where to get VGA drivers for satellite 1415-s105
Got to www.toshiba.com, use support, laptop, model number.
Arrive here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=330271&rpn=PS141U&modelFilter=1415-S105&selCategory=3&selFamily=1073768663
Narrow it down by operating system and display.
Dec 03, 2009 | Toshiba Satellite 1415-S105 Notebook
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Boot via LAN
The wake up on LAN is usually setup from the BIOS configuration.
If you BIOS doesn't have this option then it is not possible.
Apr 28, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 1415-S173 not powering up
Take out battery then try it.. if that dont work and it dont turn on then you might have to go inside..
Apr 22, 2009 | Toshiba Satellite 1415-S173 Notebook
Mar 05, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 15" Flat Panel LCD Monitor Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
