Question about Dishwashers
Dishwasher not filling with water. I checked it's not clogged, no leaks, no kinked lines.
    President:
  • 3,085 Answers
Probably a bad water inlet assembly. Easy to replace.
Posted on Jun 28, 2009
KENMORE ELITE DISHWASHER MODEL 665.12793K311 STOPS BECAUSE THERE IS NOT ENOUGH INCOMING WATER, IS THERE A CLOGGED FILTER
Check the shutoff vale under the sink where your dishwasher water line is connected to ensure it is full open. Also, check for a kinked water line to the dishwasher.
Sep 06, 2017 | Kenmore Dishwashers
Dish washer will not fill
Good Afternoon Joe - Based on the symptoms you are describing, it sounds like the hoses could be kinked or blocked or clogged water screens. If you've cleared the water screen and/or unblock any kinked water hoses, and the problem still persist after the previous troubleshooting and repairs, the unit may need a main control board replacement. At this point, I would recommend contacting a professional for a further evaluation.
Jun 06, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Kenmore 17379 dishes are not clean after running a cycle
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Glasses in upper rack not cleaning
Hi
Jan 30, 2011 | Maytag 24 in. MDB5600A Jetclean II...
Dishes dont come out clean
Hi
Jan 30, 2011 | Jenn-Air 24 in. JDB1050AW Free-standing...
Water does not fill the machine. If I put water in the machine, it cleans perfectly. The water line is turned on.
Check the hose for kinks, check if there is a screen in the hose that is clogged, remove the hose from the machine and turn the water on, see if water flows from it, listen to hear if the inlet solenoid is operating.
Jan 17, 2011 | Siemens 24 in. SE25A266 ExtraKlasse...
My dishwasher won't fill with water
There can only be these reasons:
1 Water valve shut off
2 Door not locked in
3 water relay/solenoid valve broke or inoperable
4 Plastic lines kinked for supply
5 Filter for water clogged.
I'm thinking number 3 or number 5 Hope this at least gives you some things to look at.
Jan 08, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Bottom fills with water, line not clogged
This means that the outlet valve or the drain motor is faulty or their is a leak in the pipe between them and the machine.
Sep 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Sounds like it's running but no water seems to be getting to it
Your drain m ay be clear but it sounds as though the dishwasher line may now be clogged, remove the dishwasher drain line from the trap below the sink and check for leaks. You drain nthe dishwasher into a bucket.
Mar 20, 2009 | Dishwashers
Dishwasher leaks
Sound like the fill valve is not working. I woudl check the hoze for a clogged screen ,then replace the fill valve if no clogs found.
Jan 06, 2009 | Kenmore Dishwashers
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
