Question about Hitachi 31CX6B * 31" TV
I simply want to adjust the picture - move it up
I simply want to adjust the picture - move it up so I can see the bottom. I no longer have the orig remote, but have the universal remote used w/ the Hitachi VCR
  • cgentzle Jun 27, 2009
    Thanks. I am not a tech. However, I had this problem years ago (the TV was purchased in 1996) and thought it was resloved without taking the TV case off...Of course, I may be wrong, as I've had this TV for some time....
    Pls double check to be sure there is no way short of taking it apart.
    If it can be taken apart, can the case be easily removed? I don't mind trying, but I have special electronic tools to do so and really wouldn't want to attempt it if it's difficult. The picture is find...I just don't se the entire scroll along the bottom.
    thx
    Craig
  • 583 Answers
It is bit tedious to remove the case and adjust-. if you are very much famliar with opening the case and want to try adjusting it ,only then open it or else dont open as adjusting may effect reverse too- by putting up more image in the bottom to drop and making it more worse.its advisable to get it done by manual technician if very necessary.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 28, 2009
  • 3,230 Answers
This TV do not have this function, but you can change these settings internally for that you need to open up that TV.
tell me are you a tech.? so i can assist u further.
Thanks
Posted on Jun 27, 2009
No door adjuster on my kitchen aid superba o move the door up and down.
Yes, there is no adjuster so you will (a)just have to be clever and use an old carpenter's trick. To raise the door you simply place washers of different thicknesses over the hole where the bottom pin of the door goes in.
Jan 04, 2013 | Refrigerators
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
Projector Adjustment for Magnavox 51mp392h/17
this requires secret codes not given to the public.call a tech.to repair your tv
the plublic can not repair tvs.this web site is a joke.
Jul 19, 2009 | Philips Televison & Video
JVC av-56pw30 Picture Adjustment
Sounds like you have a convergence problem and the set will require repair. This repair will run somewhere around $400 if you have a good company complete the repair for you.
If you are interested in doing this repair yourself you will need to be able to use a meter and solder VERY well.
If you have more questions please email me.
Thank you,
Tim Nolan
Experttv@comcast.net
Oct 11, 2008 | Televison & Video
I have a panasonic lumix dmc-fz7. the zoom lens no longers adjust even though it moves when powering on and off. the button used to move the zooms works to move between pictures. the camera has not been...
after a bit of research i powered off the camera removed the battery and powered it on. i then recet the it to the factory defaults and it worked fine again.
Apr 04, 2008 | Panasonic Cameras
TV picture has moved up
your pic. has shiffted vertically. very easy to fix. open the tv set, located the crt tube(end of the screen) there are four wires going down to the board that is compined in one socet. around that socet, you will find small knobs, look for vertical phase and you could adjust that pic. the adjusting should be done while the tv is on and has pic so be careful, you are dealing with a live electricity. good luck
Feb 28, 2007 | Beko 324250WN 28" TV
The picture is round
No my freind, im afraid that you have bad waveshaper capacitors in the vertical sweep circuit in your TV set. This is not an adjustment. you should have a pro assist you with the repair of this set as it is dangerous because of the high voltage inside these sets.
Sep 24, 2006 | Sony KV-27S42 27" TV
Televison & Video Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
