Question about Philips Televison & Video
I have a magnavox dvd player model DP100MW8 that suddenly will not load a dvd. You place it in the tray and it shows a disc with a red x over it in the upper right hand corner of the screen. I've tried cleaning the dvd and I've tried other dvds....all with the same result. Is there a way to reset or reboot this thing? It was working fine yesterday.
Unlucky320
  • 176 Answers
SOURCE: "wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Posted on Jul 09, 2007
SOURCE: invalid disc
we also used my husbands converter (little black and decker he has for the "office" in his truck) and we had no problems the last time we used ours
Posted on Dec 29, 2007
  • 1003 Answers
SOURCE: DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Posted on Jan 15, 2008
two DVD player with same problem. I think they are disposable. :(
Posted on Jan 20, 2008
  • 4234 Answers
SOURCE: tevion player shows BAD DISC,
Since the unit is under warranty, you can't touch anything without voiding the warranty. This problem could be as simple as a dirty lens. Bring the unit in for repair under warranty.
Dan
Posted on Mar 19, 2008
A disc is lost in my magnavox dvd player
You will have to disassemble the player to find the lost DVD.
Nov 24, 2014 | Magnavox Televison & Video
MY TOSHIBA DVR MODEL DR420KU WILL NOT RECORD ON DISC. IT KEEPS GIVING AN ERROR CODE AND NOW IT WILL NOT PLAYBACK DVD-R DICS, BUT IT WILL PLAY MY DVD+R DISCS. WHAT COULD BE THE SUDDEN PROBLEM?
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU optical pickup contain lasser beam, NOT are reading the TOC from DISK+ Syscon can be defective, you must go to the repair shop TV for fix it see the diagram attached, is a complex equipment.
God bless you
Jul 16, 2012 | Toshiba RS-TX20 DVD Recorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
How can I stop a dvd player from reading non-stop with no disc in player---player is not on lock but refuses to open.
Power off, then disconnect from the wall plug.This resets the dvd. after five ninutes, reconnect the power and start the combo. Should have 'load' on the display, then open the tray of the dvd.When you close the tray, it will try to 'read' a dvd again.
Aug 16, 2010 | Philips Magnavox DVD/VCR Dual Player
My Akai dvd player shows "no disc" after loading a dvd. The tray sometimes makes a grinding noise when opening and closing as well.
The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
All you have to do is to adjust the disc tray and screw it tightly.
To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
Take care.
Jun 14, 2010 | Akai DVPS760 DVD Player
Hook up
Salutations heybabe,
DVD players usually have copyright protection that do not allow them to be played through a VCR. The best way to connect multiple items to a single television would be a audio video switch such as:
http://www.bestbuy.com/site/olspage.jsp?skuId=7660578&type=product&id=1134701087687
You should be able to connect your VCR, Cablebox, and DVD player in to this unit and it would then conncet to your telelvison.
I hope this helps.
Jon
Go Ahead. Use Us.
Jul 14, 2008 | Philips Magnavox MWR10D6 DVD Recorder
I need a code for my dvd player
With my GE universal remote the code for my dp100mw8 is 0456. Hope that works for you!
May 25, 2008 | Televison & Video
Unlock codes
I have a Magnavox DVD player DP100MW8B, and I need to get the codes for unlock the region codes, can you help me?
Mar 29, 2008 | GoVideo VR3845 DVD Recorder/VCR
Magnavox DVD455 Player
A read of the disc has failed for a list of possible reasons; dirty media, dirty optics, failed laser, alignment all come to mind. In short, it's time for a shop service...accordianman
Feb 25, 2008 | Televison & Video
Televison & Video Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
