Question about Ricoh Aficio 2018D All-In-One Laser Printer
Change # rings before fax answer ricoh aficio super g3
I have a ricoh aficio 230 super g3 multi fn
i need to change the number of rings before the fax machine picks up the call.
It currently picks up om 2 we need 4. The manuel pick up is not a practical solution.
Hope you can help
jeff
    President:
  • 3,085 Answers
It's in the USER TOOLS menu.
Posted on Jun 27, 2009
I have a ricoh aficio 1027 with fax option and i want change the recieve function to auto answer with 5 rings
1. Download driver from http://support.ricoh.com/bb/pub_e/dr_ut_e/0001153/0001153018/V3100/r29694en.exe
2.If that doesn't fix the issue immediately try http://support.ricoh.com/bb/pub_e/dr_ut_e/0001154/0001154861/V861/r30275en.exe
Sep 11, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
I need to reset the terminal name and number on the fax portion of the Ricoh Aficio 450 copier. Can anyone assist what that?
The fax user manual for the 450 is no longer available from Ricoh, so I can't check for sure, but the basic procedure is to press the User Tools button, go into Fax Features, and under one of the tabs will be a box where you can change the fax header information.
Hope that helps!
May 25, 2010 | Ricoh Aficio 450 Copier
Aficio MP 2000
There should be a separate manual to cover the fax function in the machine. You can download one at Ricoh.com
Aug 04, 2017 | Ricoh Aficio CL7200DT2 Laser Printer
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 350 change number of rings before fax answer and/or auto detect incoming fax.
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
Mar 25, 2009 | Ricoh Aficio 350e Printer
Ricoh 1013F Fax Line answering phone calls
Not quite sure the Ricoh has what is commonly none as a fax switch. This actually catches the call and looks for the fax tone from the sending fax to determine if it is a fax or not. The Ricoh can not determeine what number is dialing in. It only knows a call is incoming.
You can ourchase a fax switch online or Radio shack had them.
Mar 09, 2009 | Ricoh Aficio 1013F Copier
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
Dec 10, 2008 | Ricoh Aficio 220 Laser Printer
Changing the number of rings on fax.
Press the "User Tools/Counter" button at the control panel.
Under the display, press the "Right Arrow" button until the display shows "4. Fax Features" & press the "OK" button
Press the "Right Arrow" button until you display "3. Setup" & press "OK".
Press the "Right Arrow" button until you display "5. No of Rings" & press "OK"
Enter # of rings with numeric keypad & press "OK"
Display will briefly show "Programmed"
Press "User Tools/Counter" button to exit back to regular display
Jul 08, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 2018D All-In-One Laser Printer Logo
871 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
