Question about Hamat 3-2861ST Everest Pull-Out Kitchen Faucet with Lever Handle Stainless...
Low pressure from pull-out spray
I too have the Hamat Everest single-handle faucet. In the last few months, I experienced a considerable reduction in the water pressure from the handle. Once removed from the hose, and cleaned out, there was slight improvement, but not enough to be noticable. I've narrowed the problem down to the spray handle/handset which has a water control bobbin at its base (by the way, the same control is at the base of the extension hose). That seems to be the problem, but I too don't know how to correct it. I was thinking of getting a replacement handle, but don't know if it'll work since the model is an older one.
  • Carlene Domangue
    Carlene Domangue Jan 30, 2014
    How do you remove the bobbins? I am having the same problem. Is there a schematic for this spray handle?
  • 297 Answers
You may try and remove one of the bobbins and see if this helps any.
Posted on Jul 29, 2009
Handle is stiff to operate
remove trim to expose valve, apply stem-grease to valve with fingers and re-assemble. turn valve on and off several times. like new
Dec 12, 2012 | Hamat 3-2810PC Everest Pull-Out Kitchen...
Where can I get a replacement hose 1.5 meter long?
Contact Hamat
Techincal Support or Warranty
Parts
Call 1-866-52-HAMAT - option 6 or extension 1242
Hours: Monday - Friday - 8:30 AM to 5:30 PM est.
email: support@hamatusa.com
Mar 24, 2011 | Hamat 3-2865PC Everest Pull-Out Kitchen...
Water is coming out around the button on top of the pull out spray
if water is coming out on top you need to replace the cartrige. If the button ontop is broken or faulty then the whole handle assembly needs replacement.
The good news is you can replace these parts for free without a receipt. Almost all these faucets carry a lifetime warranty. Simply turn off the water supply at the faucet, then remove faucet and take it to your local plumbing supply store. e.g. Home depot, Lowes, Rona, etc.etc.
Feb 22, 2011 | Hamat 3-2861ST Everest Pull-Out Kitchen...
My cartridge leaks inside the faucet. Is it possible to replace the cartridge or must I buy a new faucet?
You can find the replacement cartridge online, as Hamat is out of business...
I am ordering mine today too, www.plumbingsupply.com
about $60
Nov 21, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
I have a Hamat faucet that has low water pressure all of a sudden
I have the exact same faucet from Hamat and I just took it apart ...every last bit....the tabs on each part are notched so when you put it all back again...its pretty easy....I had every single part layed across the table.
(Below is the red neck way....without the special tool to take off the top key part which requires a special T tool)
now for the desembly.... under the handle is the red/blue button...unscrew carefully not to ruin the color...if it does not come out ...pry it out...mine was not so friendly....then take a small hex and stick it in the hole and unscrew a small screw....whalllaaa ...the top is off....now for the only hard part of this whole project....without their special tool your going to have to take a vice grip layed over a cotton cloth and clamp it on the top back side perpedicular....on the actual crome/stainless steel....this part will not be seen from the front.... I did scratch mine a bit ...but dont see it after the fix...remember it under the handle on the backside....then take another vice grip and cloth to the part you stick in the counter....(not the threads of course...just above) then with hulk like procedures your going to give it all.....hold with the left the base vice grip....and with the top ...crank it counter clockwise....again with the vice grip perpendicular ...on the back edge...I had to use a small screwdriver or rod to stick it across the vice grip for leverage.....erggggg....got it.
after that take note of how the part fall out.....eventuallly you might need to take out the cylinder.....remove the hose (did it at begininng) then wiggle....and pull out the cylinder...dont unscrew....back and forth in 10 degree turns as you pull out.....this is not screwed in.....Only One big screw already taken care off... the hoses connected in the interior are tough and for some wierd reason need a 10mm wrench.
Ok good luck....and by the way MINE DID NOT HAVE HOT WIRE...a part of rubber washer came loose from my plumbing under the counter and found its way to block hot water...inside the very core of the faucet....oh well ALLL DONE.... hot water for dishes...for my wife...just kidding.
Mar 17, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
I need to find a replacement Hamat part
Simply go to hamatusa.com and look for a dealer near you. Very good european brand by the way.
Feb 14, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Hamat 3-2861ST Everest Pull-Out Kitchen Faucet with Lever Handle Stainless... Logo
564 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
