Question about Dell Inspiron B130 Notebook
Backlight Good day... My Dell Inspiron B130 is less than 2 years old, however, the backlight went out. Faintly, I can see the Windows XP logo, etc., but it is very faint...so faint that I can't see the colors. By telephone, I have received estimates of $260-280 to replace the bulb only. Is there a less costly way to repair this? If I spend that amount, I may as well invest in a new laptop, correct? Thank you for your assistance.
  • Anonymous May 13, 2009
    I had the same problem with my b130 tried the inverter first and it wasnt the problem them i changed the backlight bulb and its fixed.
    Sergeant:
  • 324 Answers
Would you want to consider replacing it yourself? Would probably take an hour, or so. And it's not really rocket science. If it is the back light, that should run about $10-12 plus shipping. If it is the inverter, that will cost in the neighborhood of $60 plus shipping. The inverters have a tendency to fail more often than the backlights. (ain't that the way it always is?) Don't know of anyway to which it is without trying one, then if that doesn't do it, try the other.
This link will take you to the instructions on how to do it:
http://www.lcdparts.net/Laptopinverterdetail.aspx?inverteroriginal=LTN150XC-PG
R-
Posted on Nov 06, 2007
Dell inspiron 1318 lcd screen completely dim
The backlight in your LCD has gone out. You will need to replace the entire LCD. You can look on ebay or here, you will be paying around $300 for it.
Good Luck!
Jesse
Jan 05, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Problem with Fan - Dell Laptop Inspiron B130 ?
If the fan is dead, then the laptop will shut itself off after a short while to prevent heat damage. It is normal for the fan to spin up when you turn on the laptop and then stop turning. The fan will kick in again when it is needed as heat builds up. The system fan has absolutely nothing to do with the lcd lighting up.......seriously.
If the laptop is running, but the screen goes dark after a few seconds, it sounds more like the backlight on the lcd panel is shot. From what you describe, I assume that your lcd is not 'lit up' at all, but you can see a faint image on the screen. If this is the case, then either the inverter board is shot, or the backlight for the lcd panel is dead. You can try calling Dell at 1-800-www-dell and try to purchase an inverter board. They are cheap, and it would be worth the gamble to buy one, because if the backlight is shot, then you need a new lcd panel - $350+ (the backlight is part of it and not replaceable). The inverter board is located at the bottom of the display module, right behind the dell logo at the bottom of the display. It's quite easy to get at.
Here's a good test. Shut the laptop off, and attach a computer monitor to the 15 pin vga connector at the left side of the laptop. Turn on the laptop and the monitor should show you an image. If not, try holding the blue 'fn' key and press and release the f8 key. This should switch you over to the external monitor. If the laptop works fine when connected to an external monitor but has no image, then it's definitely not the fan, and you should try an inverter board. If still no good with a new inverter board, you can still use the laptop with an external monitor.
Hope this helps!.......let me know how you make out.
Dec 12, 2009 | Dell Inspiron B130 Notebook
I have a dell inspiron 6400 and im getting a black screen once the dell logo comes up and windows xp loads...I see no icons or nothing..just a black screen
it sounds like your display backlight has gone bad. If your handy you can get a new display. If you are really good you can replace the back light.
Nov 07, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron e1505 Backlight issue
when you leave the computer for a long time inactivity it goes to hibernate or standby
you can change it on control panel power options
Jul 10, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
yes your lucky thing is this problem is LCD CCFL lamp worn, change a new lamp should be fixed.
hwo to change CCFL lamp, step by step:
1) buy a CCFL lamp from eBay, reference:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+Inspiron+B130+CCFL+lamp&_sacat=See-All-Categories
2) take out LCD panel
3) open the back light cover and change the CCFL lamp, reference:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/comment-page-3/
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | Dell Inspiron B130 Notebook
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron screen backlight not working?
Try This :
1.) Look for teh power saving settings on control panel for the back light.
2.) Also plug -unplug the power input from the rear side of the notebook very fast ..
I hope that works for you b'fore you get you Macbook...
Mar 18, 2009 | Dell Inspiron 8600 Notebook
Dell B130 boots but nothing on screen and no boot up sounds
If you are seeing an shadow image on the LCD and you have video on an external monitor, then the LCD backlight has failed. The LCD will need to be replaced
I googled B130 LCD's and they generally run $125 to $200
Jan 13, 2009 | Dell Inspiron B130 Notebook
B130 Monitor Problem
Connect an external monitor at the back of your laptop and see if the display is fine. If the display is fine with the external monitor, it means to say that there's something wrong with your LCD's backlight. You may have to contact Dell Technical Support to check if your system is still under warranty.
Thanks! :)
Aug 26, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
1,134 people viewed this question
Alun Cox
