Question about Garmin Nuvi 350 Car GPS Receiver
My GPS won't acquire satellite
I turned my unit and It had lost all maps, since that time I've been trying to acquire satellites, I've had it out door in a good location but, it can't seem to reaquire satellite.
  • Garmin Master
  • 2,130 Answers
Please see thi slink for more info on this problem
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Dec 22, 2009
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Acquiring satellite
I had the same problem with my brand new nuvi 200w. I called Garmin support and they were able to help me. I live on Long Island and evidently when I first turned on the unit I had selected the "Atlantic" time zone rather than "Eastern." The support tech had me reboot the unit by turning it off, holding my thumb onto the lower right hand corner of the screen and turning the unit back on. It does prompt you that you will lose your previous settings. When I reset it and selected the proper time zone its worked like a charm.
Dec 31, 2007 | Garmin StreetPilot c340 GPS Receiver
Trouble Acquiring Satellites
This can be easily fixed....
I had the same problem, I returned first piece and exchanged for the second. Had the same problem with second and took back to Circuit city. The GPS guys took out 3rd one for me and had same problem. Then the manager came who has been using these for couple of years and tried to set the home location 3 times and it worked 3rd time. He did the same for the second returned piece and it also worked. He says since these pieces are programmed for Kansas we need to give 3-4 tried before the piece first 'locates' satellite and then acquires satellite. After the the piece just turned out to be awesome.
Oct 02, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
298 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
