Question about Omega Trane Furnace Draft Inducer Blower Fasco # A269
Optimum temperature setting for dual zone air conditioning
We're in Atlanta, GA outside temp is in the 90's.  What is the best way to set dual zone AC?  Cooler upstairs, warmer downstairs?  Vice versa? Thanks!
    Sergeant:
  • 353 Answers
Cooler up stairs
Posted on Jun 27, 2009
What is wrong with a air condition when it want cut off unless the number is set up?
Doesn't sound like anything is wrong. The number that changes is your set point temperature. (Your desired room temperature) So, if the room temp is 78 and you raised your set point temperature to 80, your machine would then kick off. Keep in mind this is when cooling. If you were heating it would do the opposite. Remember, if your setpoint temp is 78, the unit will continue to cool when it gets 78 simply because if it maintained exactly 78 all day long the unit would kick in and off 20 times per hour. Therefore most tstats will cool to 77 and not kick back on until the room temp gets to 79, preventing the machine from cycling too many times. Hope this helps!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 13, 2018 | Heating & Cooling
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
WHAT IS THE MINIMUM TEMPERATURE OF COOLING
most home air conditioners go as low as 18 c but this low setting achieves nothing but a high power bill
the purpose of air conditioning ( air conditioning -- to condition the air) is to remove the humidity ( water vapour ) form the air and allow the body to perspire more freely and so is by the evaporation of the perspiration of the body water that cools the body
this evaporation is hastened by the fact that the water vapour in the air is very low due to the air conditioner operation of conditioning the air
Now knowing this fact it is obvious that all the windows and door should be kept closed ( to remove the humidity from the room /house and so a setting of 25-26 c is sufficient to keep you cool
because the temperature difference between outside air and room air is low the air conditioner cycles less frequently and costs less to run
if the room setting is at minimum and the atmospheric temp is high then the air conditioner is running virtually all the time
so instead of asking what is the minimum temp you should be asking what is the optimum temp run to be conformable and to save on power costs
Jun 26, 2015 | Heating & Cooling
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
Dual-Zone AC Problem
My guess is that one of the hose's has a leak and needs to be replaced. A mechanic can run some tests to check if that's the case. Best of luck.
Jul 11, 2013 | 2009 Toyota Venza
Heater plows cold air on drivers side on my 2005 inpala
You probably have automatic air conditioning with dual zone capability, Please review the owners manual for the dual zone operation. I looked in the service manual and certain heat / air settings criteria have to be met before the system will work properly in automatic mode. If those conditions are not met, the system will assume manual operation and mostly play dead waiting for the user defined manual settings. Start with a good review of the dual zone automatic settings.
Nov 04, 2012 | 2003 Chevrolet Impala
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Air conditioning
On a w body car with a single temp adjustment control (not a dual zone) your problem should be a low refrigerant charge. Due to the design of this evaporator, a low refrigerant charge will cause the furthest areas from the inlet and outlet hoses (the drivers side) to not remove the heat from the incoming air. This allows the air on the drivers side to be outside temp but refrigerated on the passenger side. In cars with Dual Zone controls you must not only verify the refrigerant charge level, but also check the mode doors which control the air flow and regulate the temp. To check the refrigerant level do not use pressure gauges alone. Verify a proper charge level by checking the temperature of the two aluminum lines going in to the firewall of the vehicle. With the A/C set to high the temperatures should be within 5 degrees of each other. If not, then there is a charge issue. I hope this helps
Jul 11, 2008 | 1999 Pontiac Grand Prix
Omega Trane Furnace Draft Inducer Blower  Fasco # A269 Logo
489 people viewed this question
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
