Question about Lowrance GlobalMap 3500C GPS Receiver
Can't turn it off, it flickers and crackels. It worked ok about 3 weeks ago for about an hour, then could not find the antenna. I parked the boat and about a week later, I noticed it was turned on (sort of) and was making a crackeling noise. I could not turn it off by normal means.
  • 5 more comments
  • bob9388 Jun 27, 2009
    Thanks, I will try to find a torex driver small enough to take the thing apart. And go from there.
    I need to go to radio shack for the driver.
    No swelled or loose capacitors.
    Any other thoughts? Is this a replace rather than fix situation?
    I don't understand how this site works. If you go off the air, does it tell me and am I responding to a computer that is turned off?
    I guess you are gone - I am turning this thing off and going to work on some other projects.
  • bob9388 Jun 28, 2009
    Of course I unpluged the unit. It is on my desk and the boat and power are 105 miles away. I will power it up with the back off after looking for a bad solder connection. If that does not do it, I may just deep six the thing. Thanks for your input.
  • 2,071 Answers
You can't turn it off maybe the switch is faulty or the unit is freeze or hang .You can turn it off by taking off the power supply connected by unplugging it to the source.Flickers and crackels this the indication of cold solder.. A cold solder joint is where a lead of a component is not soldered at a high enough temperature and results in a bad electrical connection which can respond to physical shock and thermal stress.Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected . When the receiver unit turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. A solder joint may also be broken or cracked because the receiver was dropped or hit. Look on the front and back of the board along the defective circuit to see any components that look like they are not soldered effectively or the solder connection is cracked or broken. A cold solder joint looks dull and/or bulging unlike the smooth and shiny normal solder joints. Its better you resolder all components parts joints of power supply circuit board and also inaudio section.Thats is the best solution for this kind of problem its proven of all electronic technician
Regards;
Posted on Jun 28, 2009
  • 11,896 Answers
I believe there is either a bad capacitor causing a mis configuration in the unit's firmware. Check for any swelled or loose capacitors and have them replaced. Also you may want to do a system upgrade
Posted on Jun 27, 2009
  • Nate Stansfield
    Nate Stansfield Jun 27, 2009
    Yes, radio shack does have them.
No picture, No sound
It sounds that the IIC Bus circuit shorts bey some faulty components connected to it. The troubleshooting work to this section circuit is very skilled one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Digital Lifestyle FA1B32Z 32 in. LCD...
I purchased a Midland 1001z in the fall of '09 and installed it on my boat. I is mated to the existing Shakespear 8' CB antenna. The CB worked great last summer while boating with my brother and...
Vibrations on the small cb's make the internal circuit boards come loose and its intermitted or will not RX or TX.. Check the antenna with another cb. using an SWR METER.. or have someone check it.. SWR should be free if you take it to them.. to check.. Make sure the antenna, mounts, and coax are ok.. if soo then its in the cb itself .. Email us if you need more help or need the radio looked at, the post office has flat rate boxes cheap nowadays. were in Temple, TX at the CB SHop.
May 30, 2011 | Midland 1001Z 40-Channels Base CB Radio
Brake warning light comes on after car started but no apparent problems: brakes work OK including parking brake, & no impairment to driving. Any ideas? Mileage approx 112k. owned for about 3 mos,...
check the brake fluid level, if its low, it may be time to check the brakes for wear. As your brakes are used up, the fluid goes down and turns the light on.
Nov 29, 2010 | 1997 Toyota Camry
XM Receiver: When hooked up to the home kit it will show antenna and will not pick up a signal. When hooked into the car jack it works ok. I replaced the receiver mount about 3 weeks ago and it worked ok...
Hi Kldeaton,
If you can do it, try your car mount in the house, as long as you can supply power via the car plug (12-volts DC). If it does the same thing as the home kit, then you more than likely have an intermittent antenna connection on your home antenna.
Also, check the location of your antenna vs any obstructions, such as trees. You may have the reception worked out so that you have signal from the antenna, but it is "breaking up" from a connector or cable short or open condition. Check the coax for any chaffing also. Let me know if you need more help. Thanks.
Regards, Bill
Sep 28, 2010 | Delphi Roady XT XM Radio Receiver
My battery light flickers when I am at a stop sign--it goes off when i accelerate. i bought a battery and the alternator tests ok.
either the belt is slipping or the alternator is losing juice at a lower rpm....i take it it was checked in park,or taken out and tested by a machine which spins fast?
May 19, 2009 | 1992 Ford Taurus
High and low mount brake lights
Could be a short but could also be a bad ground at one of the lights!
Jan 30, 2018 | 2000 Ford Focus
Static sound when red light blinks
It might be a loose connection. Do you obly get the crackling when the red light flickers?
Dec 29, 2008 | Boston Acoustics VR950 Main / Stereo...
Check Engine light
It sound like you are having a electrical problem.You need to check your electrical/ignition system,not all electrical problem the diagnostic machine can read.
Aug 22, 2008 | 1999 Saab 9-5
Lowrance GlobalMap 3500C GPS Receiver Logo
172 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
