Question about Refrigerators
I have a Whirlpool side by side Model #ED5GHGXMB00 Serial # SP3154107 and the ice maker does not work, I have checked the arm, and made sure that the the ice bin is installed correctly, my water dispenser works-please help
    Sergeant:
  • 353 Answers
Make sure the ice isn't frozen to the maker
Posted on Jun 27, 2009
We recently had a water supply connected to our Whirlpool refrigerator model GB2FHDXWB02. After ~ 18 hours no water has entered the ice maker? What is the problem? Can I manually initiate water going into...
Make sure you actually turn the icemaker on, there is a arm that you have to trip in side that will activate the solenoid that make water enter the ice marker. Also keep in mind that the air in the line has to work out so give it 24 hours to make it to the ice maker. You should see the hose in the back of the frig, that runs from the solenoid to the ice maker. Also check the ice maker itself to make sure it is plugged in completely. Good luck
Jan 09, 2015 | Whirlpool Refrigerators
HI, I have a Whirlpool Side-By-Side Refrigerator model ED25PQXW01 and the ice maker isn't working, how do I fix it??
Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
ICE MAKER DOESN'T WORK
Make sure shut off arm is down, if it is, first thing to do is make sure water is entering ice maker, If not check to make sure inlet valve is working.Can be found where water line enters refrigerator.
Sep 13, 2010 | Whirlpool ED5FTGX Side by Side...
ICE MAKER HAS STOP WORKING IS THEIR A WAY TO TROUBLESHOOT? Whirlpool refrigerator MODEL: ED5THAXMS00 SERIAL: SP2854019
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjgkjgkj
May 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool side by side Model #ED5GHGXMB00 Serial # SP3154107 and the ice maker does not work, I have checked the arm, and made sure that the the ice bin is installed correctly, my water dispenser...
Do this simple test: add some water to the ice mold and see if it makes a batch. If it does you might need a water valve. The valve is a dual one with solenoids for ice and for water. Your ice maker solenoid is probably bad. I have a manual and some repair pix right ova HERE
Sep 11, 2009 | Refrigerators
Ice maker works but will only give crushed ice on the cube settin
little arm on side of ice bucket controls that..check it and the solenoid at back for freezer that trips it.
Jun 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
