Question about Cameras
Need 2amp buzz fuse - Cameras
  • 477 Answers
Goto littlefuse.com
Posted on Jun 27, 2009
Spb karaoke machine blown fuse 250volt 2amp changed it checked plug in wall still no power what could it be pls
You may have blown a component of the power supply, which is what took out the fuse in the first place. Probably will need a trip to the repair shop.
Aug 19, 2016 | Music
2009 CHEVY IMPALA LT 3.5 LITER 2AMP FUSE WORKS THEN QUITS WHY?
The only thing I have seen a 2 amp fuse used for is to light the buttons on the steering wheel. If that is the only problem, I would live with it. If other things start going out, Look at replacing the fuse panel, they are computers. I have replaced 6 or so in the last 2 months. Different makes and models.
Jun 25, 2016 | 2009 Chevrolet Chevrolet Impala LT
2002 GMC Yukon blows the TBC 2A fues when headlight switch is turned on
Yukon what ? XL , Denali , 2 or 4 wheel drive ?
My GM service info shows it as a 10amp not 2amp
TBC Fuse #60 10A is fuse #60 same yours ?
May 10, 2015 | GMC Cars & Trucks
Amp blowing fuse when keyed up mic
what size fuse are you using? take the wattage / voltage = amp size you need.
ie... 12watts divide by 12 volts equals 1 amp.
or 60watts/12volts=5amps
but this is a estimate range. theres always surge amps that can be added etc..
rule of thumb.
40ch only types need 2amp-5amp.
the export styles and SSB40ch will need 5amp -8amp
Dec 31, 2013 | Radio Communications
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
Fuse - 2amp for a Silvertone 1472 Amplifier
Hello endaya try www.digikey.com if you are using a 2amp buss fuse, its available, 117V is applicable to 220V, just follow the amp rating.
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I have a cobra 29 that is new and wont power up when wired up
hi have you tried checking the external fuse to the back of the unit, if i remember ( as it was such a long time ago ) i had an older version of this and there was a screw type fitting on the back ( normally black ) that houses a small 2amp fuse, check to see if this has either blown or broke, there is also an internal one on the circuit board this is also a small 2amp fuse, if it voids the warranty i would not do that one, the other option as it is new is to get a replacement...hope this helps
Feb 22, 2010 | Cobra 29 LTD CB Radio
Power issue no power
change the reverse polarity diode.
May 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cameras Logo
88 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
