Question about Dishwashers
On any cycle the digits for the time just fade in and out, no water is taken in. also if I try the 3 sec reset the 3 leds just flash continuously
  • 11,896 Answers
There is a system error in the units firmware. The unit's control board will have to be replaced.
Posted on Jun 27, 2009
What does error code E7 indicate on a bush dishwasher
E7 The appliance is waiting for a signal from a flow meter. However this appliance is not fitted with a flow meter. See below for details on how to cure this fault.
For an E7 fault the PCB has to be reset:
1. With the door open, turn the appliance ‘On’
2. Within 3 secs, push the program selection button ‘P’ 4 times
The test program has been selected if ‘Soak’ and ‘Strong’ LEDs are flashing. (This combination represents the test program for appliances that have a flow meter.
1. If the above LEDs do not flash after carrying out the above procedure, then switch appliance ‘Off’ and repeat process again
Once the above test has been activated and the LEDs are illuminated then:
2. Push the program selection button ‘P’ once to select the version “without flow meter”
bullet Check that the ‘Soak’ LED is ‘Off’ and the ‘Strong’ LED is ‘Flashing’
To complete the procedure:
1. Ensure appliance is switched ‘Off’
2. Wait for approx. 10 to 15 secs
3. Switch the appliance back ‘On’
4. Select the SOAK program to test
Nov 02, 2015 | Dishwashers
Restart off
4.4 Restart Feature
If a fault occurs in the machine, the diagnostic system will detect it. However, instead of displaying
a fault code immediately, the machine will try to restart. If the fault was only of temporary nature,
the machine will restart and finish the cycle. If there is a continuous fault the machine will try to
restart a number of times.
This process could take up to 8 minutes depending on the type of fault. After this, if the machine
still cannot restart, the fault code is displayed and the machine will beep continuously. The number
of retries will depend on the fault that it has detected, however the maximum number or retries for
any one fault is 32 times.
The restart feature is turned on when a machine leaves the factory. For servicing we strongly
recommend that this feature be disabled.
To turn the restart feature on follow the procedures below:
1. Enter diagnostic mode (Refer to Section 4).
2. Press WATER LEVEL DOWN so that the low water level LED is lit.
3. Press POWER to turn the display off (the 5 leftmost wash progress LEDs will be flashing).
4. Press POWER to turn the machine on.
5. The machine can now be tested on any cycle.
To turn the restart feature off, either repeat the steps above or switch off the power to the machine.
The restart feature can be permanently programmed in to the machine's memory. When in
diagnostic mode press and hold ADVANCE down at the same time as pressing WATER LEVEL
DOWN. A long beep will acknowledge the setting has been retained in EEPROM. Press POWER
to retain selection as with size switching. To remove from the permanent memory, repeat the
above procedure.
Note: This feature is designed as a service aid only and should be left on in the customer's
home. To return to normal operation, and to reset the restart feature to the factory setting,
switch the machine off at the wall or disconnect from the mains supply.
4.5 Recycle Feature
The recycle feature, when enabled, will cause the machine to continuously repeat the cycle that
has been selected. At the completion of the spin cycle the machine will power off briefly then
power back up again and will start the cycle programmed.
This feature would be useful to help identify an intermittent problem, and would be best used if the
machine had been taken back to a workshop for service.
To turn the recycle feature on follow the procedures below:
2. Press WATER LEVEL UP so that the Medium water level LED is lit.
3. Press POWER to turn the display off (the 3 rightmost wash progress LEDs will be flashing).
Note: This feature is designed as a service aid only and should be OFF in the customer's
home. To return to normal operation, and to return the recycle feature to the factory
setting, switch the machine off at the wall or disconnect from the mains supply.
Feb 12, 2012 | Fisher and Paykel Fisher & Paykel Washer
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
I have a Zanussi DX6453 dishwasher. Water will
Try tipping the dishwasher back to see if any water drains out from below if there is water present then the anti-flood device is energised and stopping water coming into the unit.If it works now after resetting then there is a leak under the machine that needs investigating.You can try going into the diagnostics to read the alarms.If you hold in the first and third button from the left on programmer,whilst holding in then press the on/off button then when the lights start racing release these 2 buttons.You should now be in the diagnostics,now press the first button once and count the flashes of the end of cycle LED.If this button is pressed 2 more times it will give the previous alarms.1 flash could indicate fault on inlet water and valve.2 flashes drain circuit blocked.3 flashes anti-flood device.8 flashes faulty circuit board.Make sure after reading alarms to switch off unit then on then off to reset.Then go back into the diagnostics as before to reset alarms but this time press button 2 from left all LEDS will flash after exit as before.
Hope this helps.
May 15, 2010 | Electrolux Dishwashers
CAR ASKING FOR IMOBOLISER CODE, HOW DO I INSTALL
Press reset button located to right of led for 2 seconds led will flash
Release button
After 2 secs led will flash once
Enter first digit by pressing reset button relevent number of times
After 2secs led will flash once
Enter next digit by pressing reset button relevent number of times
Repeat operation for remaining digits
if code is entered correctly led will flash
if code is entered wrong led will remain lit but not flash
Note if one of the digits of the code is a zero
after the single flash DO NOT press button but wait for next request and enter the next digit.
Oct 05, 2009 | 2000 Alfa Romeo 145
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
GOOD LUCK, EVERYONE!!!
Mar 12, 2009 | Dell 1700n Laser Printer
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
8. Cycle the power of the printer.
- Remove the power cable
- Wait for 5 seconds
- Plug the power cable back to the printer
- Power the Printer on
Feb 24, 2009 | Dell 1720dn Laser Printer
Dishwashers Logo
Top Dishwashers Experts
