Question about HP Special Edition L2000 LiveStrong Mobile Optical Mouse
HP L2000 Sudden shutdown wont power up power supply good
Was using my HP L2000 when suddenly it powered down. (went dead - no lights). Tested the power supply under load and it works fine.
Laptop will not power back up even though the battery pack is good. Tried removing it the computer still wont power up. There are no power indicators lit on the front ie connected to bower supply lamp.
Sounds like an internal problem to me. Anyone have any insite on this one?
  • HP Master
  • 2,005 Answers
What makes you think the ac park is ok
19vdc measured with a voltmeter proves this , only.
a 2005 (as old as) Laptop
its not new, things this old do fail.
Laptops are like dog years.. 7:1. so yours is 84years old
to fix a desktop is super easy
to test a laptop takes greater skills, the take down. is tricky
we take out the battery,
the the pack just make the fan run in the PC
does it>? if not the pack is bad.
or the MOBO regs are shut down. (shorts on any thing inside
some times the 19vdc is ok, at that pack
then 1 inches inside the PC its dead due to that silly power jack loves to fail. but not taking the thing down and testing that
its all just a guessing game...
the only insight there is on electronics, is power first.
no power, no joy.
test the power feeds first.
Posted on Jul 17, 2017
  • 624 Answers
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
  • 218 Answers
SOURCE: Blank/Black Laptop screen on HP DV-6000 notebook
Your symptoms sound like a known issue with the dv6000 series of HP laptops. Rather than go into a lot of detail here, let me just refer you to the HP web page about the problem. If it fits your situation, call HP at the special number shown on the page. They've been replacing motherboards even for units more than a year old. My son just got his back yesterday, and so far so good. I hope this helps.
Posted on Dec 26, 2008
SOURCE: HP Pavilion Laptop zv5000 wont power on. NOT power cord problem.
Do you have Vista? If so, you should contact HP directly. I had the same problem which occured 3 months after my warranty ran out. I called HP and was told(after they tried to sell me another laptop) that I installed the wrong antivirus program but since I never used my warranty, they would do me a BIG favor and fix it for free. I then waited 14 days for my new laptop and was very happy when it was returned only to find out 3 months later that there is a RECALL for HP laptops with the Vista program that was a MANUFACTURERS defect. THEY HAVE TO FIX IT AND FOR FREE!!!!! I hope this helps you. Good luck.
Posted on Feb 28, 2009
  • 156 Answers
SOURCE: Compaq C500- Will not turn on
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Posted on Oct 23, 2009
  • 458 Answers
SOURCE: The HP Pavillio 9700 Laptop computer will not turn on
HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
Posted on Dec 02, 2009
Testimonial: "Excellent step by step instructions"
No Power. Blown fuse or dead power supply?
Replace the power supply. Definately not the fuser
Jul 23, 2017 | HP LaserJet 1200 Printer
Hp m1160n Green light is flashing, went thru all of the steps listed, and the troubleshooting guide on the hp website.No will not turn on. tested power supply = good. tested power switch =...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Feb 27, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Model kp-53xbr4ct made 1998. picture was good. sudden went to center of screen and bowed up and down from center. it hade sound. turned of, now no sound. stand by flashes 6 times. unplugged , plugged back...
the video color distortion with the bowing in the center is called a convergence failure. the 6 blinks indicate a power supply shutdown for high voltage protect. the 14 blinks is just the tv trying to turn back on. you may be having to problems with the convergence and the 6 blinks or it may be related because the convergence amps can cause shutdown if they are shorted. i suggest calling a serviceman per the possible tow different failures. good luck
Jan 12, 2011 | Sony KP-51HW40 51" Rear Projection...
All of a sudden my panasonic th42px75u will not turn on ..tried unplugging power plug still wont turn on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem.....
Nov 02, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps;
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
Hp pavilion m7570n my little sister was playing her online game to the site for at least an hour and all of a sudden it shut down automatically and i turned it on.but the power wont work anymore as in dead
switch out the power supply and it should fix the problem. also buy a can of air and blow it out before putting the new power supply in.
here is a decent power supply. just copy and paste the link.
Aug 29, 2009 | HP Pavilion m7570n (EX331AA) PC Desktop
I have a 42" sanyo plasma flat panel tv. I was watching, and all of a sudden the screen went black. I did still have sound. I messed with the remote for a few minutes...then heard a pop...then tv was...
hello, you have a (shutdown circut) it happens when the tv senses trouble in the circut.
becuase these type of tv's run hot at high internal voltages parts can become overheated and loose proper resistance or ability to handle voltages that have to reach other parts of the circut and other internal board panels. a shutdown it is for protection. you may want to check your power supply if there was a pop that is something inside that went bad. be careful to touching inside theres is high voltages stored in the components.
i can not tell you specifically what your primary cuase was without your model service manual. no power means power supply trouble.
replace or trace.
what ever blew out cuased the power supply to go bad you will need a service manual to know for sure.
the wise chioce is to have a service center check it for you they will know what to repair or exchange.
good luck hope this helps
Jan 08, 2009 | Televison & Video
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
Thanks and Regard
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
HP Special Edition L2000 LiveStrong Mobile Optical Mouse Logo
184 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
