Question about Motorola Mobility RAZR V3
My keypad is not working
My keypad, aside from the on/off, is not working. Whenever I hit a key it starts "Voice Recording." No water damage. Please help!
  • budi raharjo Jan 01, 2008
    yup .... only the on/off key can work.
    if i push other key it will go into voice recording.
    i'll try to open it by me self later
Eric _w
all u have to do pull the back covering of the screen were u will c a ribbon that control the vol u and down the one opposite cut it off r u can just change the ribbon
Posted on Nov 07, 2007
I AM NOT CELLPHONE SAVVY ! I have an LG CG225. If someone is calling me and I do not answer and they want to leave a message, what do I need to do? create a voicemail box so they can leave a message? ...
Issues of accessing/setting up VM on your mobile or Inquiries on accessing your VM using your mobile phone?
I can help you w/that.there are 3 ways on accessing your VM via your mobile phone:
1st:
Long press the number 1 key on your phone's keypad then it'll dial your VM number and would ask for a PIN if PIN is setup.
Follow recording instructions or voice prompts and key presses until you get to hear your voice messages.
2nd:
For some mobile phone service providers,dialing your own mobile number automatically transfers you to your VM.again,if PIN is set up?it'll ask you to enter it,if not it'll automatically proceed to your VM.
Follow recording instructions or voice prompts as well as correct key presses until you hear your voice messages.
3rd:
Almost all mobile phone service providers has a so called "Voice mail Access Number"
This number can be dialled and goes straight to VM.
Voice prompts might ask you to enter your mobile number following the star key or pound sign on your mobilephone keypad.
Voice prompts might also ask you to enter your VM PIN(if seup).
Just follow Voice prompts and you're good to go.
Hope this helps.
Thanks,
FixerDelta
Sep 15, 2011 | LG CG225 Cellular Phone
Samsung s3310 keypad 789 not working Wat solution sir
SAMSUNG S3310i CALLING KEY & 2,5,7,0 KEYPAD NOT WORKING.PLS. GIVE ME SOLUTION.
Jan 08, 2011 | Samsung S3310 Phone
Hi my nokia 3110c...phone whenever...i switch the phone on...the keypad doesnt work..infact it just works a few seconds as the phone is loading..(enough time to unlock the keypad using the security code)...
Hi, when a keypad does not work on a phone, it is usually caused by dirt inside the keypad area of the phone,you can open the phone and clean up the keypad area.
Sometimes too, as the case may be Chips also can affect the keypad and allows the phone keypad not to function.
There is an IC chip inside that controls the function of the keypad.
You can fixed the IC chip inside the phone by replacing the damaged IC inside the phone.
When you replace the damaged IC .i assure soluton tothe problem.
Take care.
Oct 07, 2010 | Nokia 3110 Cellular Phone
How can you record an incoming call
To create a voice memo follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select My Stuff
  3. Highlight Audio, using the navigation keys
  4. Press the left soft key for Options
  5. Select Record Audio (2)
  6. Press the center navigation key to begin recording
  7. Press the left soft key to Stop recording
  8. The audio recording is automatically saved
To Access My Recorded Voice Notes On SGH-a707? To review a voice memo follow the steps below:
  2. Select My Stuff
  3. Select Audio
  4. Highlight the desired voice memo, using the navigation keys
  5. Press the left soft key for Options
  6. Select Play (1) to review the voice memo
Apr 03, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Voice Mail recording
the voice mail key is the #1 key on the keypad as well it should have an envelope icon on the keypad as well, just press and hold the #1 key and follow the step by step instructions to setup you voice mail.
Sep 28, 2008 | Sony Ericsson W850i Cellular Phone
Razr V3r; Any key pressed turns off phone
Try Replacing the keypad. It's tricky to do exspecially on a GSM phone if you need directions how do do it email me at hoferron@hotmail.com. I need to know if it's a GSM or a CDMA phone before giving you directions. You can get cheap keypads off from ebay
Sep 01, 2008 | Motorola Mobility RAZR V3
Only thing phone will do is go to a voice recording from 2 months ago
you need to have the keypad flex file reflash into the phone or have the flexcable replaced.
Apr 02, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Help
Web link with the manual is http://www.rcapearl.com/pdf/TH11xx_IB.pdf
If your lazy he's the cut and paste from the manual;
1. To start voice recording, press M twice to access the Home menu.
2. Press or to highlight “Voice Recording". Then press to advance. (thats the key you would press to skip ahead a song)
3. Press or to highlight “Record”. Then press to access voice recording
mode.
4. Press when the display shows “Ready” to start voice recording.
5. Press to pause record. Press again to resume recording.
I had a hard time myself with this fuction so don't feel alone. I used the voice record to record a lecture and it was surprising sensitive but then again I had the professer put it in is front shirt pocket. It would over modulate a bit but was audioable and served its fuction for me
RoB Goins
RobertGoins@hotmail.com
Nov 22, 2007 | RCA OPAL M4001 MP3 Player
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
