Question about Kenmore 15864/15862 Top Load Washer
Need to know where coulping is located a diagram
  • 370 Answers
Go to Sears.com. Then click on the parts direct link at the top of the page. Then it will ask you for your model number. After you put your model number in, you can view many diagrams of your washer.
Posted on Jun 27, 2009
Is it a good idea to rebuild your carb after rebuilding your motor
Most certainly it is. It should just go along with the rebuild regardless if it is ready or not.
Jun 05, 2016 | Cars & Trucks
How to disassemble a GE Profile Electric Dryer model# DPVH880EJMG
the element is usually located on the bottum rear of the dryer. there should be access in the rear or the entire front comes of wit a coulpe of screws from below the door and then it will be under the drum. hope this helps
Nov 29, 2014 | GE Dryers
Spring popped out of front wheel and steering is not easy
Detach the wheel and fix it in a vice, taking care not to damage the axle.
Pull or pry the gap open and put the spring back in place.
I did it a coulpe of times, pretty easy once you know how to go about it.
Feb 15, 2014 | Baby Jogger 2010 City Select Baby Stroller...
Do not know vacuum hose locations---need diagram.
Isn't there a vacuum diagram sticker under the hood of your car?
Jan 15, 2014 | Cars & Trucks
Does not spin and makes a cranking noise
This may be a motor coulping problem. I replaced mine today on a Kenmore it took 30 minutes time and a $25. part picked up locally. Was able to get a good diagram on line to take the housing off the machine and move the necessary parts to get to the coulping. Smile, clean clothes are not far away!
Jan 15, 2013 | Maytag Bravos MTW6600T Top Load Washer
We had a power surge coulpe days ago and now the ranger doesn't work. You turn on the burner the light goes on put no heat and on the display it say PF. What should I look for? Thanks, Bill king
"PF" is a Power Failure alert, as you probably have figured out by now. According to the owner's manual for the model you have listed, you need to press "OFF" on the control panel anytime "PF" appears to clear. The, reset the clock if required. If this does not correct the problem, you may have a defective control board.
These control boards are often suseptible to power surges and electrical storms. If you determine the board to be defective, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
searspartsdirect.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. Hopefully, this is just a simple operator intervention issue that does not require parts.
If you have any questions please post back and let me know. I hope you find this information helpful.
Jun 24, 2010 | Whirlpool RF378 Electric Kitchen Range
No electric's, main fuse has blown, need to know location of same to replace. If possible, can diagram be sent?
under hood. you have to raise up the box and flip open side covers to unbolt 120 a41948728mp fuse.
May 28, 2009 | 1991 Lexus LS 400
No Fuel to the engine - 2003 yukon XL
The relay should be under the hood located inside the small black box that is about 6 or8 inches square. should be a diagram inside the cover showing which is for the fuel pump relay. If you have someone else turn the key, you should be able to hear or feel it click for just a coulpe of seconds when the key is turned on. Straps on tank have a bolt that holds one end and they are held on by a T-slot on the other end.
Apr 17, 2009 | 2003 GMC Yukon XL
Location of horn in a 2005 jeep grand cherokee limited
The first thing I would check is the fuse for the horn. If it's blown, it's a cheap and easy fix. If you have the user's manual for the vehicle, it should show you the location of the fuse for the horn. Pull it, and check to see if it's blown. Aside from that, it could be that they disconneccted it below the hood. A Chilton's manual or a quick online search will help you locate the horn connection between your steering column and the horn itself. If there's a wire unplugged, just plug it back in. If both of those yeild no results, I'd find another dealership, or a trustworthy mechanic to help you diagnose.
Oct 24, 2017 | 2005 Jeep Grand Cherokee
Kenmore 15864/15862 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
