Blower fan noise
Blower fan making squealing noise when running, no access door
  • 11,896 Answers
The cover should be able to be pulled off. The brushes inside motor are wearing out and brushes or entire fan motor will need replaced
Posted on Jun 27, 2009
Pontiac g6 2006 heater/ac fan doesnt work on #3 speed setting, fan made squealing bearing noise for a while but quit, also inside/outsied air vent switch vent makes clicking noise when set to outside air
you will need to replace the blower motor as it has probably siezed going by the squealing noise you say you heard.i`m assuming this has more than 3 speeds for the fan motor.if it wasn`t working on one speed then you probably have a bad blower motor resistor that will need to be replaced as well so you will have all fan speeds.this is located in the air duct housing near the blower motor and will have about 6 wires on it.some of these on under the hood on the firewall anywhere from the passenger side to the center of the firewall.not sure about the vent switch.if the vent switch is moving the doors and you hear a clicking then you may have a vent door problem that the door pivot is worn.
Nov 01, 2013 | 2006 Pontiac G6
Enviracaire filter system makes squealing noise when blower fan for funace kicks on
Sounds like you are on the right track, the machine is starving for air. Remove filter and test in auto. If no noise then either you still have a "bad seal" somewhere or the filter is simply to think or restrictive. I can't ask you to test the static pressure but that would be a sure test on what is going on. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 04, 2017 | Honeywell Heating & Cooling
1991 nissan maxima squealing clicking noise behind the dash
while clicking is happening place your hand on the heater blower motor and you will feel it coming from there. change the blower fan.
Apr 07, 2017 | 1991 Nissan Maxima
Squealing sound when air conditioning is on and turning left
same problem...not an a/c issue. When the fan is on and when you turn left.sounds like something rubbing in the blower. took the blower off, no obvious blockage.
Apr 19, 2012 | 2003 Pontiac Vibe
Very loud "squealing" noise from fan blower for
Hello, if you cannot turn the fan by hand then the motor is shot. However, when power is applied to the motor and it starts after you give it a push then its the capacitor. Whenever you replace a motor tje capacitor must be replaced aswell because the microfarad rating of tne capacitor may have changed.
May 30, 2011 | Goodman CKL42AR42 Air Conditioner
Excessive noise when a/c blower fan on high, runs fine on medium or low. how do i get to the fan blower compartment to clean out any debrie?
Need to turn the glove box door upside down. To do this, there is a metal "S" shaped part in an opening on the left side of the glove box when open. Stick your finger in there and release this spring loaded metal piece, the door will now fall down. From the bottom, you need to remove the plastic kick guard below the glovebox to access from the bottom.
Feb 23, 2011 | 2002 Chevrolet TrailBlazer
For past 6 months dryer has been making a noise while drying and when I turn it off sounds like it is still spinning for a second. Now dryer is making a squealing noise as well and not drying the clothes...
Sounds like the blower wheel (fan ) is loose on the motor shaft.... that is the spinning you are hearing...
but the fan/blower is not running full speed so it is not moving enough air...
heatman101
Jan 18, 2011 | GE DBXR463EDWW Electric Dryer
Heater blower making a squealing noise
hi this may be the bearings in your heater fan gone u/s and possibly dry unfortunately the only answer to this is replace the fan ...hope this helped
Feb 23, 2010 | 2005 Chevrolet Silverado
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Heating & Cooling Logo
356 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
