Question about Toshiba Satellite A60 Notebook
Background size When I turned on the computer the background image has gotten smaller about 75% of te screen size, but the desktop icons are all the regular (normal) size.
  • 385 Answers
Re: background size
Try changing your screen resolution to a higher one.
If doesn't work, try reinstalling the video drivers.
Posted on Nov 06, 2007
0 characters
3 Points
How do I change the desktop text, icons and bars back to 100% from 500% in Windows 8.1?
Hi Cindy
You have set a customer DPI scale for your display.
Right Click on desktop
Choose "Screen Resolution"
Click on link that says "Make Text and other items larger or smaller"
Click on link that says "Set custom text size (DPI)"
Adjust the scale back to 100%
Apply the changes and all should be well.
Make the text on your screen larger or smaller Microsoft Windows Help
May 18, 2014 | Acer Aspire PC Laptops
Zoom on desktop
Try Right Clicking on a empty space on the desktop and select Properties. Click the Settings Tab and go change the screen resolution. The higher the resolution, the smaller the icons. Normal resolution is about 1024x768, but you can make the icons even smaller by increasing the resolution.
If you can't get into the screen resolution that way, turn off the computer and boot up into safe mode.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
When the computer boots up click Start/Control Panel or Start/Settings Control Panel and look for Desktop or Appearance and Personalization.
Look for Screen Resolution or open the desktop and click the Settings tab. Make the resolution higher to make the icons smaller. Normal is 1024x768 but you can make it higher.
In Windows 7 just click Start and in the search box type: Screen Resolution. Look up at the top for the returned search results and click on Screen Resolution. Go in and set the resolution higher.
After you change the resolution reboot and let windows go into it's normal boot up mode.
May 23, 2012 | HP Compaq 6710b Notebook
My dad fixed this problem by changing the background on his computer. I know this sounds like a strange fix, but apparently certain backgrounds just affect the load time and I think that's what this "2 min" icon was representing. His icon has now disappeared.
Feb 26, 2012 | PC Laptops
Why i cant change my background in my laptop ..?? how can i change it??
There are multiple ways you can do this.
method 1: Exit out of all programs. With mouse on empty desktop, right click. A little white window should come up that will have different options. Click anything along the lines of "Personalize". Continue exploring the options until you reach an area that says "desktop background" or something to that effect. You will have a choice of different backgrounds that come with the computer, usually scenes in nature or graphic designs and so forth. Click "Set" or "apply" or "save" or whatever your option is.
method 2: For a custom background, go to google and search images. Search whatever image you want football team logos, nature scenes, etc. Select your image by clicking. Select "Click to see full size image". Make sure the image is zoomed in all the way. Right click in the center of the image. A window will come up with options. Click "Set image as background". Viola. You have any picture as your background. Make sure you use a large image though, if you care that it covers the whole screen. It may be blurred, if it is not large enough or in high enough resolution. You can do the same process for photos of your own that are downloaded on your computer.
Jul 22, 2011 | Acer Aspire 4730-4947 Notebook
I can not change desktop background image
What do you mean you can't change your background image? Please clarify. Do you need instructions on how to change it? Or you have tried and it won't work?
If you have win xp, right click with your mouse in the middle of the desktop (away from an icon) then choose "preferences" and go to screen saver and then also wallpaper and choose another image. Make sure you save before exiting.
May 02, 2011 | PC Laptops
How do i set laptop background image on my compaq 615?
This can be found in the Help and Support section of Windows on your laptop.
To change the desktop background
  1. ? click on your desktop-Select personalize. This will open a window that asks you to select your desktop background
  2. Click the picture or color that you want to use for your desktop background.
    If the picture you want to use isn't in the list of desktop background pictures, click an item in the Picture location list to see other categories, or click Browse to search for the picture on your computer. When you find the picture that you want, double-click it. It will become your desktop background.
    getcontent.aspx?assetid=8456a207-d4c8-401d-8729-c5dda3f0e72c&documentset=en-us&prod=win700&market=usLook for pictures in other locations on your computer
  3. Under Picture position, click the arrow and choose whether to crop the picture to fill the screen, fit the picture to the screen, stretch the picture to fit the screen, tile the picture, or center the picture on the screen, and then click Save changes.
  • If you choose to have a fitted or centered picture as your desktop background, you can also frame your picture with a color background. Under Picture position, click Fit or Center. Click Change background color, click a color, and then click OK.
  • To make any picture stored on your computer (or a picture you are currently viewing) your desktop background, right-click the picture, and then click Set as Desktop Background.
getcontent.aspx?assetid=7abb27d7-2989-4144-81e3-0a51f703885d&documentset=en-us&prod=win700&market=usThe Set as Desktop Background option
Apr 24, 2011 | PC Laptops
How to change my wallpaper in my laptop
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don't forget to vote
Feb 12, 2011 | PC Laptops
I want to change my desktop background.
hope this helps
Jan 30, 2011 | PC Laptops
Icons are to large for my screen
Right click on desktop,
select Properties,
click settings,
adjust the screen resolution,
click apply,
if not better then try different resolutions until you find the icons are the right size for you and the desktop is the right shape (ie not stretched and not black areas around the edges
Sep 20, 2009 | HP Pavilion dv6000z Notebook
Alienware glitches
if your useing vista turn off window transparency.
Apr 15, 2008 | PC Laptops
Toshiba Satellite A60 Notebook Logo
102 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
