Question about HP DeskJet 3940 InkJet Photo Printer
It won't print at the moment . yesterday it had a jammed envelope which i was able to remove and now it won't print. The licht on the printer continues to flash. mhenzell@btinternet.com
TRY TAKING OUT THE INK CARTRIDGES AND SITCH OFF PRINTER FOR A FEW MINS THEN PUT CARTRIDGES BACK IN
Posted on Jun 27, 2009
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
Where do you put envelope to print on it?
You are brave trying to print to an envelope...remove paper from tray, put in "plain" envelope, print side down, flap should point to left ( I put a dab of glue stic on flap to hold it securely) will print from top or bottom tray. If envelope keeps coming out askew...make sure to check for a wayward piece of paper stuck in roller from last paper jam.
Aug 04, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Where to place envelope.
This should be in your manual complete with pictures.
You can print a single envelope using the photo/envelope feeder. Insert the envelope into the photo/envelope feeder with the side to be printed facing down and the flap to the left.
You can print multiple envelopes (max 20) from the bottom tray. Temporarily remove the top (output) tray. Slide the paper guide in the bottom tray to the left. Load your envelopes to the far right with the side to be printed down, flaps to the left (I like to tuck the flaps into each envelope so they are less easily jammed, but this is optional). Slide the paper guide to the right snugly against the envelopes. Replace the output tray. Start printing.
Dec 21, 2009 | HP Deskjet 6940 InkJet Printer
How do I print envelopes? It just jams when I
when you load the envelop, you should make sure that you adjusted the tray to lock the envelopes in place, or otherwise, they will move and cause a jam
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I was printing an envelope that g ot jammed.How do
remove the cover of the pc and take a 9V battery and put the terminals of the battery to the terminals to the motor which should be right under the roller. if you can't get to it then you have to remove the roller(s)
Jul 31, 2009 | IBM 4230 Model 102 Matrix Printer
Hp l7580 carriage jam - how to fix it
use the back door for printer and you can remove the envolupe
May 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
Paper Jam inside the printer Lexmark 5470
Firstable, you need to remove these pieces of paper from your printer. It is possible just removing a part of the printer located in the back or the bottom of it. Then you need to know that if you want to print on an envelop, it's necessary to format the printing settings. Just go to printing format and choose envelop
and also the dimensions of the envelop you want to print, then after this it'll be simple.
Dec 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP DeskJet 3940 InkJet Photo Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
