Question about 2wire (1000-000057-000) Modem
Power light cycles to red, no other lights on
Repeating cycle:
- Power light blinks green, while only the wireless green light comes on. (Ethernet, internet, DSL lights off).
- Then, power light goes solid green, while all other lights are off
- Then power light briefly goes solid red and the cycle starts over again
  • 25 Answers
Hi der... well the issue your facing is simple to say ur power adaptor is faulty. Usually its due to some electrical shorts or maybe some heavy lightnings. You can always have a remedy for it.
1st : Buy a new adaptor.
2nd: call ur ISP to have it replaced if ur still under some contract term or if the modem is still under warranty.
3rd : you can buy ur own ADSL2+ modem from supporting outlets . Make sure ur isp supports this modem.
This are the solutions for ur problem pal.. So make a wise decision.. Any needs and help post it to FixYa..ANd the experts here will fix ya..!
Posted on Jul 07, 2009
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
I have a Toshiba 46hm94P. Just replaced the lamp. Now I get the TV trying to start. It will reboot 8 times, with the green light blinking 8 or 9 times while the red light is on. The TV will then turn off...
make sure the lamp cover is on because sometimes they have switches on them that turns the on when the cover is on but if its off tv might not come on. If thats not the problem then you might have a bad ballast. Call a local tv repair shop.
Jan 20, 2010 | Televison & Video
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
The power light on my actiontec m1000 blinks green & red and now my computer can't find the modem. What does the blinking lights mean??
hey
red light on modem usually means modem is in bad state
in this case kindly try to do power cycle
way to power cycle
disconnect all the cables and leave the modem for 30-50secs
then try and connect power cable first
then connect the dsl and then ethernet and see if that resolves the problm,
Sep 18, 2009 | Computers & Internet
5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
May 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Playstation three power problem
This is probably like the "Ring Of Death" that is included also with the Xbox 360. You might need to replace it. Have you been using it over a long period of time?
Apr 26, 2009 | Sony Playstation 3 (PS3) Console
Red/Green Light Problem
Had same problem after only 3 months, tech looked at it said had a power circuit problem causing it to keep cycling, they exchanged my TV. No problem since.
Oct 29, 2007 | Toshiba 46HM95 46" HDTV
PICTURE WENT BLANK TV TURNED OFF
Replace the thermal fuse part# 1-910-006-44 You can verify this by jumping the connector where the fuse connects and the lamp will come on.
Aug 20, 2007 | Sony KDF-E55A20 55 in. LCD Television
2wire (1000-000057-000) Modem Logo
596 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
