Question about Toshiba CF32H50 TV
One of the 3 primary colors is missing from the CRT. Is it fixable and at a reasonable price? What parts need to be replaced?
When I turn the projector on I get scattered bright white pixels showing up on the screen with no color. What causes this.
Hello!
Bad news: the problem is the light engine! most expensive part of the projector. Due to high temperature inside and extended usage with poor ventilation, plastic filters inside the light engine start melting and picture gets "spotty". Next, the color matrix quits and one of primary colors is missing. In any case, light engine is "goner". It's very big job to replace it. I would surrender to repair facility in your place. Or, if you can get replacement projector for a good price, just do that. Your projectors repair bill might be $500+,or more. due to high cost of light engine.
Good luck,
thanks,
Alex.
Dec 21, 2011 | Panasonic ET-LAC735 Multimedia Projector
Heard a pop sound, lost color, now i get loud buzzing no picture lamp light flashing and it turns itself off and on
Color wheel need to be replaced, required color wheel is available in Samsung Parts, click the link to view image and price info.
Thanks.
Jun 25, 2011 | Samsung HL-P6163W 61" TV
Hcl crt color 15" digital monitor.red color is
Unfortunately, this is not a fixable problem. Samsung CRT monitors are well known for losing color; they have defective cathode ray tubes. I recommend that you buy an lcd screen. sorry if that wasn't what you wanted to hear! don't forget to rate
Jan 13, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
The tv screen color is red no matter the color adjustment
hello, Confirm that the source is not a weird color video - try another channel or a tape. Verify that this is not a missing color problem - one of the primary R, G, or B, has disappeared. If so, refer to the section: Intermittent or missing colors. Once these have been eliminated, you are left with the following possibilities: Defective part around the chroma chip/circuit. Misadjusted color oscillator. Bad connections or short circuit in area of chroma chip/circuit. Defective chroma chip (don't suspect this first just because it is probably very expensive). Bad degauss circuit resulting in lack of degauss or abrupt termination of degauss current rather than smooth tail off. The CRT is not being properly demagnetized and color purity is totally messed up. Bad CRT - the shadow mask has been damaged and it is impossible to properly adjust purity across the screen. NOTE- This will require a skilled personnel to handle this
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Samsung 931b Monitor is red
loose CRT board solder or chroma ic and transistors problems..
Mar 09, 2009 | Computers & Internet
HAVE NO COLOR ON THE HI-DEF. CHANNELS,ALL OTHER STATIONS ARE FINE.
The green CRT Tube is available at the following link. They sell good used parts for reasonable prices with freeshipping. Also if you mention you need speakers as well they have been known o include small additional parts at no charge just send them an email.Here is the link.
http://servicemanuals.vstore.ca/
Feb 23, 2008 | Televison & Video
ViewSonic G810 21" CRT
if that is a new and have a waranty why did back to the store and need for the replacement if the monitor has a warranty ...so just bring that and need for replacement...
Jan 15, 2008 | ViewSonic G810 21" CRT Monitor
Rings of Color
You will need a degausser. Check out Wikipedia for the definition. Look on ebay or your local TV repair shop. Cost should be $20-$100.
Dec 13, 2007 | Panasonic CT-27SX12 27" TV
Televison & Video Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
