Question about Paul Decorative C771-31 Products Valhalla Kitchen Faucet with Metal Lever...
I am having trouble turning my price phister faucet. I mean, it will barely turn from side to side at all!!! Have a house water softener, have tried to lubricate it, with no luck. I have taken it (somewhat) apart and can not find what is binding. Any ideas?
  • 297 Answers
There is a washer inside the neck of this faucet.the washer has gone bad.you must replace it for the faucet to work right.
Posted on Jul 22, 2009
How do you change the filter to a culligan water softener
Here are instruction to remove the filter housing. This is from my tips posting. Culligan filter housings are just Pentek/Pentair water filter housings and these tips apply to virtually any filter housing.
Frequently whole house filters can be very difficult to remove. The canisters become almost impossible to loosen, even after pressing the pressure relief valve and using a housing wrench. The most common reasons for this are the housing was put back on with the housing wrench, debris in the housing threads and a bad pressure relief valve.
h2oservices.jpgl76w9ont156vs3p099e2rqu+8nt56e+fbm9ldnps+cnj57dmpqamzqoj3nqs4doe4cr7sqwf8acoamtivyaikaaaaasuvork5cyii=
How to remove a stuck filter housing.
1. Turn off the incoming water.
2. By-Pass the Softener
3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.
4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).
5. Press and hold the pressure relief button to relieve pressure further.
6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).
7. After removing, clean housing thoroughly, make sure threads are clean on filter bowl and housing head. Lubricate threads of housing and head with plumbers faucet lube or silicone.
8. Clean and lubricate the O-Ring (replace the O-ring every couple years or if housing leaks after screwing back on). It helps to flip the O-Ring over a couple times per year.
9. Replace the cartridge filter and screw the housing back on.
10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.
11. Open outlet and let water run to cold water faucet until all air is purged.
12. Put softener back in service.
IMPORTANT! Only tighten the filter housing by HAND!
NEVER use the housing wrench to tighten the housing.
I hope these tips help you with the angst of removing stubborn filter housings.
RJ
Sep 29, 2011 | Culligan Sediment Water Filter
Tip
Removing Whole House Filters
http://i.fixya.neth2oservices.jpg
RJ
on May 30, 2011 | Culligan Under Sink Water Filter
There is a knocking sound from inside the faucet and it is leaking under it
when plumbing knocks and shakes the fittings I never seen it being the fauect causeing it. What it sounds more like that you have a loose pipe in the wall. That will bang every time the water goes on and off.
All single handle faucets are quick shut off which does not help to stop the bang. It makes it worst.
Try at first to turn off the water to the house, then open every fauect in the house and on the out side. I know it sound nuts, but this is what you are doing. when a house is bulit they install an AIR CHAMBER this is no more than a section of pipe 12 to 24 inch long with a cap on the end.
This traps air inside, you can compress air but not water so this acts like a shock absorboer that stops water hammer.
Now turn the water back on and then tirn off all the open fauects. If it stil does it you might have to open a wall and strap down the pipe work. also get some flex water supply lines for the lav faucet this will let the pipe move without making any bang soounds
Sep 08, 2011 | Price Pfister Single Lever Handle Faucet...
Hi, I have the 1600 NG tankless water heater. Everything works great, but I installed low flow hot faucets throughout the house and now the igniter will not click on. It works for the washing machine. ...
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#flow
1) Tankless require minimum flow rate before burner will activate.
2) Sounds like the water pressure drops quickly when faucet turns on. This implies combination of problems including sediment build up inside lines, crossover at single-handled faucet, or sediment filter clogged or water softener clogged.
3) Low flow faucets can reduce needed flow rate.
4) Other problems can contribute: sensor failure, loose wires, PC board failure, high temperature setting, cold incoming water temperature during winter months.
Jul 20, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
I have a price pfister pull out kitchen sink 533 series. the hot water barely runs out of it. the cold water runs great. but the hot water 15 feet away in the half bath runs great. What is my problem?
There is a restriction in the valve or the stop from supply is restricted,check stop at sink to make sure it is opened all the way,if it is then turn off water supply disconnect hot water to faucet take container open valve slowly to see if it is restricted,if that is open and water flow is good.Then it is in the faucet you must then disassemble hot side cartridge and see if there is some type of blockage if none visible the with hot side disassembled slowly open valve to see if you can flush out any foreign matter (note the way it is disassembled so you can reinstall exactly how if was taken out to avoid any reassembly problems).
Jun 14, 2011 | Price Pfister Plumbing
Is the price pfister 016-HH7C shower head any good and does it have good water pressure?
I have had good luck with price phister brands, they are as good as any, and they stand behind them. Water pressure is variable depending on where you live, If you live in San Diego, you have great pressure, If you live in Old Town, FL, you have pump pressure. The faucets can be hacked into for more water, but not necessarily more pressure. If you have good pressure now, you can expect the same. Hope this helps.
Jun 11, 2010 | Price Pfister Home
No water flow in gooseneck faucet
Sounds like the diverter part (insode the faucet) is clogged or broken.
May 27, 2009 | Price Pfister J103-BC 100 Series Kitchen...
My price pfister bathroom faucet wont shut off.
you may need a new fucet...the manifold opening for the cold has probably craked or split
contct price Pfisterrdirectly they may send you a new faucet
Price Phister is more about looks than function they want to keep their marketing sales
when I built my house I ut rice phister in because of the looks ..function was marginal
Jan 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
KITCHEN FAUCET (single handle PRICE Phister ) suddenly quit flow
Take it apart and clean out calcium lime or rust build-up. Also check to be sure your shut-offs are clear and running well
Jan 09, 2009 | Price Pfister Marielle Kitchen Faucet with...
Paul Decorative C771-31  Products Valhalla Kitchen Faucet with Metal Lever... Logo
99 people viewed this question
Top Paul Decorative Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Paul Decorative Plumbing Expert? Answer questions, earn points and help others
