Question about Singer Sewing Machines
The underside stitch is a mass of loose thresd
    New Friend:
I have the same problem. Mine is Brother
LS 1217
Posted on Jun 15, 2013
    New Friend:
I have the same problem. Mine is Brother LS 1217
  • 208 Answers
A mass of loose thread on the bottom of the fabric most likely indicates a total loss of upper tension. Remove the upper thread, raise the presser foot and rethread the machine. Make sure that the upper tension knob/dial is around 5. If you still have a problem, let me know what brand and model you have.
Posted on Jun 27, 2009
Loose stitches 2212
Be sure to Always Raise the presser foot when threading the top thread. This may help with your situation.
Aug 27, 2017 | Sewing Machines
My sewing machine is lemeiux 7000 . My thread is breaking and Seam from the lower side is very loose .what could be the reason
It is a tension problem, check your needle to make sure it does not have a burr this will cause thread to break.
if the stitching is loose on the underside you have to figure out if it is the top thread going to the underside and making loops of thread, your tension is too loose so tighten ever so slightly and sew a few stitches till it is even, if it is the bobbin thread that is bunching up try re threading it and make sure you are using the same thread on both bobbin and top, some will not work together. hope this helps good luck
Jun 13, 2017 | Sewing Machines
The underside of the stitching is loose how can i fix that I toyed the bobbing that did not work please help!!!!!
When the underside of the stitching is loose the problem is most likely with the top thread. Unthread the machine then rethread it making sure that the thread is securely in the tension disk and the machine is correctly threaded.
Jun 01, 2017 | Sewing Machines
Bobbin tension
Masses of thread on the underside is actually a top tension problem. If you can see into the top tension area, make certain there are no jammed threads, lint, yecch in there. Lift and lower the presser foot lever and see if the tension opens and closes. If it does not, it may be stuck open and not putting any tension on the top thread. Make sure your top tension is set in the middle of its range.
Apr 28, 2012 | Singer 57817 Computerized Sewing Machine
My bobbin stitch is loose. I have tried adjusting tension and have changed the needle.
A. To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim.
Sep 20, 2010 | Singer Curvy 8770 Electronic Sewing...
Tension underside looks good, but top side the bobbin thread show
sometimes when you reset the top tension dont forget to reset the bobbin tension so try to tighten the bobbin tension
Nov 08, 2009 | Kenmore Sewing Machines
The thresd gets knotted and it won't stitch
Rethread your machine
Make sure your cotton runs through the two tension plates
Check that your top tension is set on 5
Make sure your bobbin case is threaded correctly
Lastly, make sure there is no cotton stuck between your top tension's plates(take a long needle and remove any fluff)
Sep 14, 2009 | Singer 6038 Mechanical Sewing Machine
Stitching too tight on top
I found a screw on the bobbin case (where you put the cotton for the underside stitching) which was very loose. I tightened it and that created more tension for the bottom thread which solved the problem.
Jan 02, 2009 | Bernina Activa 130
Stiching
It's very possible the bobbin is in upside down and the thread is coming out of the lower tension. Pull on the thread and the bobbin should turn counter clockwise if it is correct . If it turns clockwise, flip the bobbin over , put the thread through the lower tension and try it again. The topside stitch is loose either because the lower tension is loose(or non-existent) or the top thread is too tight.
sewman7
Jul 06, 2008 | Janome 4623 Mechanical Sewing Machine
Sewing Machines Logo
164 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
