Question about Honeywell Programmable Thermostat Heater
Can I swap a Honeywell L641A1005 cylinder thermostat for a L641A1039 stat
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: wiring honeywell digital stat
Hello davem1952,
The way you wire it will depend on how the other end of your three wires are wired into your heating system. This link http://www51.honeywell.com/pacific/common/documents/DT200_Specifications.pdf
shows the various methods for wiring it and take into account the type of setup you are dealing with. You'll need to find the wiring detail ( last page) that corresponds to your setup..
Hope this helps..
Reagrds,
Rick
Posted on Dec 13, 2008
lasvegasrich
  • 65 Answers
SOURCE: Looking for user's manual for older Honeywell
go to this link and put in your info
http://safemanuals.com
richie
Posted on Nov 05, 2009
SOURCE: Is it possible to change the thermostat L641a1005
Yes this can be removed without draining anything. It only mounts on the surface of the hot cylinder tank.
Posted on Nov 16, 2009
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
Honeywell l641a1005 schematic
The boiler frame should have an EARTH ground. Everything in the system uses the frame for all the needed grounds. A wire from anywhere on the frame to a good connection on a water line is normally what is used when the boiler is installed.
Jan 27, 2014 | Heating & Cooling
Replaced immersion heater water warm not hot, could it be the honeywell L641A1039
have you checked the thermostat on the heater element is turned right up?
Mar 23, 2013 | Heating & Cooling
My thermostat wont come back on
You have to reset the t'stat probably if the t'stat didn't have a battery back-up
Nov 03, 2012 | Honeywell Programmable Thermostat Heater
Honeywell CT500 Electronic Thermostat showing 73 deg room temp when room temp is actually 77 degs. Can thermostat be calibrated?
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Aug 13, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Honeywell thermostat manual
The model number is going to be on the thermostat. It is not unusual for the number to be on the back of the stat, meaning you may have to take it off the wall. It could also be found betweenthe base ans the stat.
Once you have the model number googel "Honeywell XXX" with XXX being the stat model number. If you can't find the stat, you can go to the Honeywell web site and do a search, matching your stat, by the pictures and functions. It is a bit tedious, but it works.
Jul 22, 2010 | Honeywell Programmable Thermostat Heater
Honeywell T86F thermostat (controlling oil-fired hot water baseboard heat system) comes on on demand but will not cycle back on after zone cools - or it just takes too long???
T-Stat started smoking when activated last night. I swapped it out with one from another zone and have ordered a replacement. - www
Nov 24, 2009 | Honeywell Heating & Cooling
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
HONEYWELL T-STAT
it is always advisable to shut down the main swith to avoid further issues in replacing thermostat, if you follow the right color coding this should be no prob, unless otherwise it cannot detect the right temp then it will not stop until it reaches and senses the right temp.
Dec 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,303 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
