Pull one of the spark plugs, get the name and number from spark plug. Go to your favorite auto store and get the same spark plug.
Even if you go to walmart, they will have a catalog there close to spark plugs, look up your year--make--model and engine size.
Different manufacturers may use different gaps? I did look up motorcraft spark plug for your vehicle, I believe the gap was .050.
I usually go with the cheapest spark plugs that are listed for the vehicle, just because of the cost. The cheapest may not be the best.
search What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
not to bad you'll need long extension, front one are there in view, the back one's remove spark plug boot (long one) and with extension you can reach spark plug's.
Notice: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage. Gap the spark plug, using round wire type spark plug gap gage.
Gap Adjust the spark plug gap to 1.14 mm (0.045 in).
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
If your going to use Platnum plugs, DO NOT GAP them. Just check the gap and if there not the right gap, ask for new one's with the right gap.
The metal on the PLatnum plugs, are harder and my break apart in the cylinder .
