I have a Smasung DLP. The LAMP goes on blinking for 15 sec after that goes back in STAND BY mode. What can I do to fix it?
  • 3 more comments
  • simionrsaa Jun 27, 2009
    I see nothing on the screen. It turns gray for 15sec and black after that.
    Samsung DLP HRL4667 WAX. Yes the stand by is blinking ones every 30 sec.
    I have Smsung HRL 4667 WAX. The stand by is blinking every 30 sec.
    I have not rejected your support. However there is no solution in your response.
    Thank You!
  • 294 Answers
Boss let me help u step by step.
Firstly its a common problem that comes with the kind of Samsung DLP ypu have. now the issue as mentioned by you is that it blinks for 15 minutes and goes back to stand by which means as per my experiance it goes dark. there can be several pronlems related to the issue.. which i will explain one by one before that i wanna let you know that some times there is song Beeping sound which in your case i assume it does not occur cos you have not mentioned.
have you ever replaced your lamp ? if not your Lamp has been working well lately but as per my experiance the Lamp has gone really bad so i think you need to check out the lamp which is a halogen lamp in almost all the cases so it may look ok from out side but there is a chance that the lamp need to ne replaced. please try going to the link where you will find the datails of the lamp, compitability, price etc. http://www.samsungparts.com/Default.asp
Also please Try checking Fan #2 when the TV shuts off, it is the fan that cools the lamp. It should still be running to cool the lamp, if not, that could be your problem. The lamp is overheating due to FAN 2 failing. Normally you will get a message on your TV set that says the fan is failing, however, in rare cases the sensor also fails with the fan. the philips lamps available in the market are the best for the procuct you are currently using. you can also get the best quality and at right price from Discount-Merchant.com
now that you are done with the lamp the second reason for the blinking and stand by mode is due to the failure of the Ballast. Lamp is still good and the ballast failed or both are bad. If the lamp physically looks OK, not blown, then it's quite possibly a bad ballast. I have had bad lamps that looked perfectly good
So as my second guess is WEAK ballast. The lamp that D-M sold you is indeed new. The ballast may be weakened due to normal wear and tear. A new lamp requires more Umph to turn on than a older lamp that has many hours on it. At times, some people may receive a new lamp in the mail and put it in and it doesn't work even though their old lamp worked and just had low luminosity; this is the sings of a weak ballast. If you turn your TV on/off many times a day, you will weaken your ballast and may blow your lamp faster. For this reason Bars show up to 10,000 hours on their lamp. The leave the TV on for hours an DLP's are meant to run that way. They are like cars and their spark and starter system. If you are leaving the room for 5 minutes, don't turn off your TV. It takes a lot out of your ballast and lamp to turn back on, plus it's bad for the lamp to be turned on and off without the proper cool-down time. Also after time the capacitors on the ballast seem to rott, which cause the ballast to start failing intermittently.
Here is a good link to great information:
http://www.fixyourdlp.com/blog/2007/04/07/how-to-extend-the-life-of-your-dlp-lco s-sxrd-hd-ila-or-lcd-tv-lamp-intuitive-guide/
i could be surprise if it does not solve the problem that you have mentioned.. as many customer who come to my workshop with the simillar problem where sorted out with above tips..
have nice time.. >> cheers!!
Posted on Jun 27, 2009
  • 11,896 Answers
It is most likely a bad capacitor in the power supply that will need to be changed.
  • 10,594 Answers
Please intimate exact model number of your Samsung TV and do you see standby light linking when TV shutdown after power up?
Thanks.
  • Shahid Electronics
    Shahid Electronics Jun 27, 2009
    OK, I was reading your model info and you rejected my assistance and we opportunity to fix this TV.
    President:
  • 1,383 Answers
Go to control panel and open power and option
then check in power scheme that turn off monitor after 20 minutes is right1.
Also check in 3rd hibretation tab disable hibernate.
  • kishor
    kishor Jun 27, 2009
    When you power up the computer press F8 key then if you can able to see safe mode and other thing then it is your screen resolution problem.
    For that5 enter in enable vga mode. then go to dispaly property then change screen resolution to 1024*768 the apply and ok.
    And if you can not able to see that safe mdoe and other menu then your samsung dpl has some hardware isssue.
  • kishor
    kishor Jun 27, 2009
    open your samsung monitor back sdie and clean dust from all circuit.
    Also reattch all connection in circuit.If you can then check.
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
No picture
Check the lamp contacts, eventually remove lamp and fit back in, chack that you did not burnt new lamp when mounting it in, you need a multimeter to test lamp.
Aug 10, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
My samsung dlp shuts off after about 15 seconds
3 years its about that time to change the lamp. Call local repair shop for lamp availability.
Jan 10, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
RCA DLP HD50LPW166 Works fine for 15sec
Same Problem here. After some investigating and speaking with one Lamp supplier they told me to replace the Lamp Ballast first (this is mine EUC 120 P/H11 9137 008 09405). I found one on Ebay. Since this may also wear out the bulb, I may have to replace that also. If I can get my TV working (HD50LPW166YX6) for around $150.00 for both, I'll be happy even if i get only 6 month of use out of it. Did I mention the TV was free? :o) Hope this helps.
Mar 22, 2008 | Televison & Video
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
