Question about Garmin (010-00583-00) for nuvi 750/760/770
My 765 cut off and will not turn back on.
When traveling home the other day my 765 turned off and now will not turn back on. any ideas, or fixes. I have been searching the blogs and have found no great solution.
Garmin has a major software bug with all of the 7X5 units. My unit just got back from service. If it will not power up you will have to contact Garmin for a RMA number and send it back to them.
Posted on Jul 08, 2009
How can I stop the beeping noise when going in reverse
Find the buzzer and disconnect wires from there, or cut one or both of the wires at the buzzer and tape the connection to prevent shorting.
Apr 01, 2015 | Pride Mobility Products GoGo Elite...
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
Pride travel scooter cut s off
This is usually due to the battery "jumping" off the contacts when you go over a bump in the pathway. Put a RUBBER door stop between the battery and the seat post. This fixed mine for all but the huge potholes. Had this fix for 4 years
Aug 04, 2012 | Pride Mobility Products Go-Go Elite...
Hardware Error 03130031-2E23 Turn off printer, wait, then turn on again I done this twice and it does not fix the problem, it just repeats the same message. Any ideas what the problem is?
This error on the Canon iPF-605 wide format printer means that there is a problem with the paper cutting knife. The knife (black block) should be at the left front side in it's rest position.
Powered the printer down and moved the knife block from right to left, powered on and voila: problem solved ! Thanks Canon support!
May 19, 2011 | Canon Office Equipment & Supplies
Purchased LG's LHB335 home theatre 5 days ago to enhance my LG 42LBX TV. Problem with home theatre sound as the audio cuts out for a couple of minutes every 15-20 minute intervals. Problem is intermittant...
i bought mine in january 2011 and just started having the same problem. i have to turn the head unit off and back on again to get sound back. any fixes for this yet?
Dec 06, 2010 | LG LHB335 Theater System
Asus A626 keeps cutting off
I had a problem similar to this, and I used YOUR solution to fix it. In fact looking for you to thank you for the idea is how I found this problem.
Sometimes even with the battery cover on and intact, the sensor does not correctly detect it. My screen was turning off randomly and sometimes would not even get through the Asus init before it would turn off again.
So, looking at the solution you posted I pushed a small wad of Kleenex in the hole and then put the cover back on. It's been running fine for almost a day now.
So, thanks for the suggestion. I had no idea that sensor was there.
Jan 04, 2010 | ASUS MyPal A626 Pocket PC
My chain saw (14 inch gas powered) would not
Modern chainsaws have the ability to run without turning the chain via the chain-brake. To set the brake the uppermost handle is pushed forward (toward the chain) and a firm snap should be heard and felt. To release the brake you pull the same handle back (towards the engine) and get the same "snap".
Concerning oil leakage: Bar/chain lube collects on the inside of the clutch cover and the sawdust mixes with it as you saw. A surprising amount of oil gets absorbed in the sawdust and later seeps back out when the saw is at rest. If the level of oil in the tank noticably drops after sitting overnight you may have a leak...otherwise it's normal.
As for a running chain that wont cut, it is common for chains to be installed backward and the unit still function perfectly (it just won't cut wood). See the proper chain orientation here. In this photo the chain travel is from left to right.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Travel Drive Broke
It depends on your skill level as to if it can be fixed or not. The data is most likely still safely stored on the flash chip inside the drive casing. However, the USB connector has been just ripped off. If you have any experience soldering it would be as simple as getting a replacement usb plug from an electronics store or cutting a cable you have and then soldering the USB connector back to the flash drive inside the casing. This is something than can be done at home or possible by a repair shop that does any type of soldering work(tv, radios, ect) Most computer repair shops will look at you silly if you ask them to solder a thumb drive back to life. I would not expect more than to be able to mount your drive and copy the data. Odds are after you cut it out of the casing it will never go back in correctly.
Good Luck
Aug 21, 2009 | Memorex Electronics - Others
KitchenAid KESK901SSS Oven door wont open after blackout
My kicthenaid oven door locked when a breaker tripped. I live in a sm. town. Some of my friends had to cut through the metal lock, then take the whole thing out the back of the oven along with some kind of spring. Don't try this at home. And make sure the power is turned off. These "Good 'Old Boys" can fix everything - and without the manual. The good news is that you don't have to pay a service man or buy parts. Just don't ever turn on the self-cleaning oven part again. I can get the guy to tell you how he did it.
Mar 25, 2008 | KitchenAid KESK901SSS Electric Kitchen...
Dropped Camera Zoom Problem
Afraid not a novice or even an expert can fix this one. It will have to be a repair of the zoom mechanism. It will almost certainly be costly. Check your Olympus support site to see what your local repair options are.
Aug 30, 2007 | Olympus Camedia C-765 Digital Camera
Garmin (010-00583-00) for nuvi 750/760/770 Logo
269 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
