Question about Pentax Optio E60 Digital Camera
Same problem My camera is less than 4 months old...Took it on our first family vacation and it reads Lens error 0x041100000
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 24, 2012
2 Suggested Answers
  • 11967 Answers
SOURCE: pentax lens Error 0x0311
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 29, 2010
I have a Panasonic DMC-FX12 digital camera. Before I left on vacation, I took all the pictures OFF of the camera and recharged the battery. I took only 4 pictures before the error message "Built in...
You copied all your pictures, but they still exist on the memory card. You need to go into the menu and erase the pictures. As far as the lens not coming out, there may be some dirt in the mechanism.
Oct 20, 2010 | Cameras
I have a Fuji finepix j38 that is appox. 8 months old. When I turn the camera on, the lens comes out, immediately retracts, and "zoom error" comes up on the LCD. I can view pictures, but can't take any. ...
I thimk your problem is that you have sand betwin the lens mechanism and that cause the immediately retract.you can try to apply air pressure near the lens but with care
Oct 05, 2010 | Fuji Cameras
Canon SD100 Lens Error (camera)
First try calling 1-800-OK-CANON to see if warranty repair applies. If not...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 12, 2009 | Canon PowerShot SD1100 IS Digital Camera
Error message F-- Nikon D90 w/kit lens 18-105mm
correct - i need to get a good grip on the lens and click it to connect to the body
Jun 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon Coolpix S202
My nikon coolpix s210 had a "lens error" after several months of use. The tapping of the camera against my hand did not work. Eventually i did use the method of putting my nail under the lens and pulling as I tried turning the camera on. I had to apply a good amount of force and was afraid i would break the camera, but after doing this several times, the lens did click back into place.
Jun 01, 2009 | Nikon Coolpix S210 Digital Camera
Lens error coolpix l6
The lens is probably stuck with a piece of dirt or something jamming it. You could gently try and pull on the lens with a slight turn in each direction to see if you can dislodge the particle.
Some individuals on the internet have felt comfortable enough to try and disassemble the camera to reveal the parts of the lens drive mechanism, clean it and put it back together and this sometimes will help (but that is beyond this response) because there are enough locations on the net that describe this.
Since it's 4 months old, you may want to return it for a replacement.
Other alternatives are:
  1. Carefully use some compressed air around the lens mechanism.
  2. Take the camera back and get a replacement, or
  3. Talk to Nikon and get it serviced.
Hope this helps, if it does, please choose FixYa!
ThankYa!
Nov 10, 2007 | Nikon Coolpix 5200 Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
Dont know if this will help anyone. I had a lens error for ages. In my long lasting devotion to google serk I found that many equall contenders found that a strike with a soft book in different directiions solved the problem. I ended up beating the camera from all angles with the palm of my hand. But hey! it worked. 4 months later im looking for the cure to system error 2. If you can help wi that one.
Sep 11, 2007 | Nikon Coolpix 5200 Digital Camera
Pentax Optio E60 Digital Camera Logo
32 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
