Question about Kenmore HE2 Plus Front Load Washer
Our basement flooded...about 3 feet...our dryer is working, but the washer is saying "F-28" which in my manual says it's an electrical problem. Also, when first looking, we thought it was working fine becase it turned on and you could switch the cycles and stuff, so i put bleach in to run the clean washer cycle and then it registered the F-28 signal...it also locked and we can't get it unlocked now... Is there anything I can do to avoid the cost of having a repair person come to look at/fix it?
  • 15,935 Answers
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
4 month old admiral dryer. Basement got flooded. Very little water hit bottom of dryer. It tumbles but has no heat. What do I do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Dryers
Basement flooded,Dryer runs but wont heat
heatman101
Jul 26, 2011 | Frigidaire GLGR341AS Gas Dryer
My basement got flooded and my kenmore elite now don't want to start
you have a bad motor,i live in boston and we had some floods here,every dryer i checked that got wet needed new motors,the washers were fine,check with a meter to see if power is going to motor,if it is and it's not starting you know it's the motor.good luck.the motors are easy to change out yourself
Oct 12, 2010 | Kenmore 63942 Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Kenmore HE2 Plus Front Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
