Question about Ryobi 18v Cordless 5-1/2" Circular Saw P501 18 Volt
I'm trying to figure out if I need to hold the lower blade guard up while the saw is running...there is no lock for it
  • Craig Butler
    Craig Butler May 11, 2010
    It's supposed to stay down (to protect your fingers) and as you run the saw blade into the wood it pushes it up.
  • 285 Answers
No you do not need to holde the lower blade guard up. It should be spring loaded and move upward as it engages to piece being cut. depending on what you are cutting, you may need to hold it up to start the cut, but then it can be let back down while cutting. It is a safety feature designed to keep as much of the blade covered as possible during use.
Posted on Jun 29, 2009
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
How do you change the blade on a miter saw
first unplug the tool, raise the head and loosen the bolt that holds the lower guard in place. DO NOT disassemble the lower guard, pull it down and it will move out of the way somewhat. Next there is a spindle lock that you push in rotate the blade until locked and hold it while removing the hex bolt, which should be left hand thread, I would use a pair of gloves when holding the blade just for safety. Remove the outer flange and spacer (if needed) reassemble in the opposite order and before trying rotate the new blade by hand to make sure turns freely. Let me know if you need more assistance.
Feb 16, 2011 | Saws
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
Feb 02, 2011 | Porter Cable Portercable Pc186cs 18v...
How to change a blade in a sears 10" compound miter saw
there should be a spindle lock on this tool, lower the blade guard without removing and hold the spindle lock and the screw is usually left hand thread.
Aug 31, 2010 | Craftsman Saws
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
I have a 10"DELTA Miter Saw and need to change blade. Please describe how to remove and replace blade. Thanks
Without a model number I cant look for this saw, but if it is like the other mitre saws that I work on, the lower guard should have a bolt holding it in place, loosen the bolt so you can move the guard and the blade bolt is usually LH thread, on the backside of the gearcase by the blade there should be a spindle lock, rotate blade until it locks and then remove bolt. If your saw is different please give me the model number and I will pull up a schematic and look at it.
Jan 16, 2009 | Saws
Ryobi 18v Cordless 5-1/2" Circular Saw P501 18 Volt Logo
204 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
JOHN LAPIER
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
