SOURCE: The volume control is stuck
samsung web site has a firmware upgrade for this problem.
but I tried this and this does not work as the version is the same.
http://www.samsung.com/us/support/download/supportDown.do?group=televisions&type=televisions&subtype=lcdtv&model_nm=LN40A650A1F&language=&cate_type=all&dType=D&mType=FM&vType=R&prd_ia_cd=02010100&disp_nm=LN40A650
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
SOURCE: Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
