Question about Shuttle SN85G4 (sn85g43200) Barebone
Integrated ethernet not recognized by XP after fresh install. Computer is a Shuttle XPC SN85G4 v3. The adapter lights up when plugged into my network. The computer previously plugged into that port on the router had no problems connecting. I have already updated the chipset & bios drivers from the Shuttle website. I have enabled the onboard ethernet in the bios. The only thing that shows up in Windows XP is the 1394 connection. I have tried the Add new hardware wizard, didn't work. I have tried pinging the router from cmd prompt and that also didn't work. Someone please help me. Thank you!
  • 596 Answers
Realtek 8201BL chipset is the network drivers you will need. You should be able to find this online. When you do download the drivers, be sure to download the 64 bit drivers for your systems or you will run into further problems.
Good Luck
Franklin
Posted on Jul 21, 2009
What's your problem?NEED HELP PUTTING WINDOWS XP HOME EDITION
It sounds as if you have a failed or failing hard drive. Replace the HDD and then go for a re-install.
Nov 05, 2012 | Shuttle Computers & Internet
Shuttle computer will not finish boot up process
This is usually because the operating system is corrupt. Try to start the computer with the OS disk in the drive. This may work, if it doesn't I would suggest getting a new copy of the OS.
Jun 24, 2012 | Shuttle Computer Shuttle Xpc X27d-bk-v1...
My Integrated ethernet not recognized by windows 7 after fresh install. I have a Shuttle XPC SN85G4 version 3 Barebone System
Even though your system was built around the AMD 64-bit processor, the componets are still 32-bit hardware. Windows 7 is a 64-bit based os. You can perform a windows update to try to download the latest drivers for your system. Also, visit Shuttle support website for more information about Window 7 drivers.
Worst case scenero, reinstall Windows XP/Vista.
Good Luck
C2Solutions Support Team
Jan 10, 2011 | Shuttle SN85G4 (sn85g43200) Barebone
My shuttle pc gets part way through booting windows xp then makes clicking noise and gives up. Rebooting in safemode causes it to get partway through the xp files and then stalls
Sounds like you might have a bad CPU. If possible, try another hard drive in the system (just to eliminate the possibility of a bad hard drive) first, but my guess is the CPU.
Dec 18, 2009 | Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC...
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Shuttle SN85G4 (sn85g43200) Barebone Logo
530 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
