Question about Uniden TRU 446 Cordless Phone (TRU446)
Uniden CallerID not working..
I tried all the diff methods to make the called ID work.. my normal phone shows the caller ID but this cordless phone from UNIDEN just doesnt show up the number.. Can't get caller ID on my cordless although caller ID is available on my fixed line phone. Anyone has any solution?
SOURCE: Uniden CallerID not working..
sell it off
Posted on Jun 17, 2007
0 characters
1 Points
My Uniden 8055 is shoingno caller id when I ring my mobile phone, how do I make it show caller id on all outgoing calls?
Try this .go to menu,then settings , then call settings ,then press' Show caller Id.'I hope this works for you .
Feb 09, 2015 | Uniden DECT 6.0 Cordless Phone ID
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Phone with Digital Answering System has Caller ID Problem - Its not showing the caller Id's and phone book enteries.!
cannot see the caller id working or it doesn't display the number of who is calling. bought these phones a month and half ago.
Feb 20, 2011 | Uniden DECT 6.0 Cordless Phone ID
Negative, the SX 50 does not support CID. You can upgrade the Mitel or use a CID Multi line interface to a PC. Here is one such model.
If you go to the bottom of the page on the right, click on how it works. Hope this hlpes.
Jan 15, 2009 | Uniden 5.8GHz Cordless Phone
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Feb 08, 2008 | Panasonic KX-TG6702B Twin Cordless Phone
Caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Feb 01, 2008 | Uniden TRU9480 Cordless Telephone
Uniden phone 5.8ghz
Make sure that you have caller id service from your phone company. If you do not have a different phone with caller id borrow a working one from a friend and see if it shows up on a different phone. Let a phone ring at least twice to give caller id time to work. If a different phone does not show the call information call your service provider.
Jan 28, 2008 | Uniden TRU8885-3HS Digital Cordless Phone
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Oct 27, 2007 | Uniden Cordless Phone
Uniden TRU 446 Cordless Phone (TRU446) Logo
23 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
