Question about Frigidaire Washing Machines
Something hitting as drum spins dry sounds like
Something hitting as drum spins dry sounds like maybe a sock got between drum and wall of tub
  • Anonymous Mar 17, 2014
    something is blocking the drum from spinning. it can spin only about a foot either way.
  • 31 Answers
It could be your spider has gone or your bearings have gone.
Posted on Jun 27, 2009
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
SOUNDS LIKE UN HAVE SOME ITEM OR COIN ETC STUCK BETWEEN THE TUB AND WALL. YOU HAVE TO REMOVE THE TOP PANELS THEN REMOVE RETAINER CLIPS AND REMOVE THE BODY TO ACCESS INSIDE DRUM
Dec 12, 2016 | Kenmore Washing Machines
Electrical/rubber odor when load is complete
Not many machines are belt driven these days, but the symptoms are those of a slipping belt, or friction against a failed rubber mount.
To find out more you will need to remove the case (or enough of it to see what happens while it is working.
Be on the lookout for some rubbery thing (either a part, or something from a previous load) jammed somewhere where the rotating drum scrapes it.
A burning rubber smell is different to a burning motor windings or transformer smell but maybe only to afficionados. Could be a winding failure on the motor too.
Unplug, un-case and plunge your schnozz into the works seeking the odiferous source. Sounds like I am kidding, but I am not - really try it. You may need to dry run it for a while to elicit the smell before unplugging etc.
Please post how you go, and what it eventually turns out to be.
Feb 03, 2018 | Bosch WFMC 3200 Front Load Washer
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
How do i get into the cabinet to remove an obstruction from outsi
hi from uk if the object sounds as you say between outerdrum and wash drum ? may i suggest you unplug machine and disconnect water supply pipes then remove the rear panel this will give access to the main drain hose from bottom of outer drum which also connects to drain pump this hose is rubber and held usually with circular spring clips each end ? remove hose and you may be lucky the offending item/s?? will be resting hopefully near hole? if you use a piece of wire coat hanger you may /will locate item at the bottom of drum with a little patience? and you never know thge mysterious missing sock ? bra wire/ or the thong ? sure you've heard this b4 ? ps with rear panel off you can also rock the drum and listen for item's location ? and with hose off you can check pump for debri/fluff too hope this helps best wishes
Feb 16, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum is hard to turn
does your dryer have a plastic glide on the drum or is it on the felt if some one gave you the wrong one that would make your problem worse there is two different types for that dryer
Jan 16, 2007 | Kenmore 83042 Electric Dryer
Drum is stuck
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub. Open washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. keep a rag nearby to dry up spillage of water when removing the rubber host. Good luck !!
Jul 01, 2006 | AEG Lavamat W1050 Front Load Washer
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
