Image runner 550
I need to print different sizes within one job (ie: mostly 8.5 x 11 with some 11x17 mixed in). Is there any way to have the machine automatically print to the correct size without having to go in and change it manually each time the 11x17 sizes come in?
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
If i recall, canon DOES have a function for that.
look in the menu it will be " mixed originals" select that and it should work.
There was a problem I encountered once with this, the customer was making mixed sizes and it was all coming out one size, the problem was that for some reason the first original had to be a Letter size ( I think). then it would recognize the papers.
Posted on Nov 13, 2007
  • 69 Answers
Hi im jules_09,there no way it can print automatically with 2 different size its not programed the way.because once you copy a document the copier doesnot automatically select the ize of the paper your going to use its you thats going to do that
Posted on Nov 07, 2007
I can't print on multiple size pages in the same job.
if there is a setting , it will be in the printer set up
however if there is not , you have to alter the page size before pressing the print button
Dec 12, 2017 | HP Laserjet P3015X Printer
Unable to print from canon imagerunner 3100
Select the paper source(paper tray) on the computer,select paper size.
Jan 03, 2012 | Canon Diplomat Office Equipment & Supplies
We have a Canon Image Runner 3235 that is hooked up to a network. Every time we try to send more than one document to print off we get the error message to load paper and it doesn't need any paper. ...
if the message add paper related with specific paper size i.e. add A4 paper in drawer, first you need to check is the paper senzor in drawer set to correct paper size - it is blue circle with markins of paper size. Second thing under printer driver properties on PC check if the correct paper size is choosen.
Hope that helps!
Aug 15, 2011 | Canon iR 2016i Black and White Copier
49,4c18 error
A critical firmware error has occurred.
1. Turn the device off and then on.
2. Try to determine whether the error occurs intermittently, while printing, or when turning on the device.
3. If the error appears while printing, determine whether it occurs when printing from a specific computer, a specific application, or a specific file. If all other computers, applications, or files
can print without the error, then the problem may be only within one print job or computer. Make sure the computer has the most current printer drivers, or use a generic printer driver.
4. Go to Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the device and the device can receive a firmware update, download the newer firmware upgrade.
Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
6. If the message persists, contact your HP Support.
Feb 22, 2011 | HP LaserJet P3005n Printer
On a Image Runner 1023iF trying to print letter envelopes loaded in the Stack Bypass. Machine once it received the print job just beeps and flashes.
did you select the correct paper size on machine display? When you put paper in baypass the copier ask you for paper size and type.
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
For some reason our Canon Image Runner 2270 started printing in landscape versus portrait. We did not touch the machine and the printer setup shows portrait - I assume I have to change something on the...
Check your paper size/orientation dial on the paper tray you are using. I believe this machine uses this dial to tell the machine what paper size and orientation is loaded. Make sure the dial matches the size and direction.
Aug 20, 2010 | Canon imageRUNNER 2200
Canon W8400 printing.
Hi Did you get an answer I have the same problem.
May 24, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Large paper printing
12 x 18 is the largest size paper that can be used on this copier. If anything larger is used the machine will jam. The copier uses a series of paper sensors to track and time the paper throughout the printing process. The max is 18 inches anything over that cuase the machine to jam.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
I have a Canon Image runner 1023. when I print i get the message load paper A4, change reg'd size, common settings. and the error light is flashing
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Nov 17, 2009 | Canon imageRUNNER 1023N Black and White...
Help I can't get a Word doc to print on 11x17 on my canon Image runner 2200
guessing its the wrong print driver go to imagerunner ,com and look for different driver
Oct 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
49 people viewed this question
