Komodo k600 scanner
I have a komodo k600 scanner - new in box. how old is it? is it still usable? what is the value?
ColorPage - Vivid4X
Posted on Jun 29, 2009
REALIST VHFHI-AIR POCKET SCANNER .IS IT STILL USABLE WITH NEW FREQENCIES ?
Yes....non-digital frequencies. Depending on what youre trying to listen to and what they are using.
Dec 17, 2013 | Uniden BC92XLT Handheld Scanner
Unlock k600 code
Do you want to unlock LG K600 from the network lock? .IF it so means you can get the unlock code from an online vendor like Unlock-Zone.com .To get the code you need to submit your country name, network provider name and IMEI number.
Oct 22, 2013 | LG Cell Phones
I want to read text file which is located in c drive using java code can anybody help me out
import java.io.*;
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
parser.processLineByLine();
log("Done.");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
scanner.close();
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
scanner.useDelimiter("=");
if ( scanner.hasNext() ){
String name = scanner.next();
String value = scanner.next();
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
scanner.close();
// PRIVATE //
private final File fFile;
private static void log(Object aObject){
System.out.println(String.valueOf(aObject));
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
Jun 22, 2009 | Sun Java Programming Language (cdj-275)
I have a handheld uniden bearcat BC60XL T-1. It got some kind of dampness on it from an air conditioner vent. It worked fine until then. I have removed batteries and let them dry out but still won't...
fire that trunking scanner up,the uniden is damaged,there should be no difference in signals since june 14,they are all still there,just get a new copy of the codes from radio shack,or use an online scanner,http://www.broadcastify.com/listen/?rl=rr
Apr 22, 2017 | Uniden Office Equipment & Supplies
Komodo K600 (WIN98) on XP
Is it possible to use the win98 program and install the driver using the XP compatability wizard?
Start, Programs, Acessories, Program compatability wizard,, then Next, "locate program manually"
please post back resultas so we all learn
Jul 06, 2008 | Office Equipment & Supplies
Sceptre X9G Komodo IV 19 in
check out any dry solder or burnt and re solder it , hope it helps AJ
May 03, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor Powers off after a second or two.........
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Sylvania 42
Check the fuses on YSUS & ZSUS boards, if found the fuse blown on that board, just try to replace the board.
Dec 30, 2007 | Sceptre X23gv-Komodo 23 in. LCD TV
62 people viewed this question
jasbo
jasbo
