Question about Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower
My mower is getting fire and gas but all it will do when you pull is back fire (pop) but it wont seem to start
Sounds like the fly wheel key is sheared making the engine out of time. Check and make sure you dont have a bent blade too, When the blade hits something the key will shear off so it doesnt damage other things but the blade may be bent as well
Posted on Aug 11, 2009
    Sergeant:
  • 353 Answers
Starving for fuel, clean air filter, clean carb
Posted on Jun 27, 2009
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Lawn mower won't start
Check spark plug grounded when pulling starter to see if you get fire First. Then , spray(if getting spark at plug) starting fluid in a air intake , if motor fires, you're not getting gas so clean gas tank and carb, then , it should run fine.
May 07, 2014 | Mtd 22" Yard Machine Push Mower
Model 944.361200.mower won,t start in colder weather,once temp gets above the70degree mark it will start,but blue smoke comes form exaust.mower will start right away every time once engine is hot.fresh gas...
I have a mower with a Honda 165cc engine that is temperamental as far as the initial start up is concerned.
Once it has started it always fires up first pull
The problem seems to be the gas is slow to reach the carb / cylinder
I have developed a ritual for starting up.
Open the gas tap.
Lean the mower back until the hand bar touches the ground.
Raise the mower and lift the hand bar so the back wheels are off the ground for a few seconds.
Fully open the throttle, Hold the ignition control back and operate the pull cord.
If it doesn't start first time I am usually rewarded with a promising fire-up.
Sounds wacky but works for me and used to spend 20 to pulls on the cord to get it to fire .
Oct 24, 2017 | Garden
Torn down Yard Man wont start
Fuel related if you can get it to fire with starting fluid.
May 12, 2013 | Mtd Garden
Toro Mower wont start
take sand paper and shine up the magnetio with is on the flywheel shine them up and put you hood back on it it will start
May 12, 2013 | Toro Garden
I have a poulan 6.25 self propelled mower that wont start soun like its not getting fire
First make your kill handle is pulling your cable all the way back.Sometimes the cable will rust or even break inside its sheathing. to test take a peice of wire and tie it off by pulling the arm all the way back then start it. If that works replkace kill cable
Jun 17, 2012 | Poulan Pro 22" Self Propelled High Wheel...
Stanley riding mower wont start but gettin fire and fuel
its getting fuel to the carb but is the solenoid working on the bottom of the carb they stick and also safety switches go bad and kill the power going to it
May 28, 2012 | Garden
I have a toro snow blower that makes a popping sound when pulled but wont start any ideas
Have you tried using starter fluid? Sounds like the timing may be off or it may be flooded. Pull out the spark plug and see if it is wet. If so dry off the plug and pull the engine over with no plug (move the spark plug wire away from the spark plug and ground it out so it wont cause a fire). This will spit out the excess gas in the cylinder and then put it back together and try again. What model is the Toro?
Nov 12, 2011 | Toro Lawn Mower With Toro Power Tools
Wont start
does the machine have a safety lever you pull in before starting as i have seen them needing adjusting as it earths coil out,to further check coil you can always remove cut out lead from coil and pull starter with plug out to check spark ,hope this is of help,let us know how you get on
Apr 08, 2009 | Garden
Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP  Gas Powered Lawn Mower  Logo
296 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
