Question about Sony Ericsson K850i Mobile Phone
The touch button which is labelled as 'back' presses itself?
The touch button activates itself? Whenever i press the arrowed buttons or any numbered buttons, the 'back' sensitive button presses it self and when i write a text, it just keeps pressing for no reason?
  • 3 Answers
Solve your problem for FREE OK I HAVE A PROBLEM WITH MY DODGE 2002 3.3 VAN CAN YOU HELP
Posted on Jun 27, 2009
Instructions for brother p touch 1000
Instructions1 Turn on the device by pressing the power button. If this is the first time that the machine is being turned on, select a language with the arrow buttons and press the return button. Select a unit with the arrow buttons and press return. Set the date and time with the keypad and the return button.
2 Type in the text for the label using the keypad. Correct mistakes by pressing the "Backspace" key and retyping. Press the return button when the text is ready.
3 Select the appropriate styles and features for the label. The device will provide you with a wide range of choices for the size, style and width of the text. Simply select which feature you would like with the arrow buttons and press the return key to move on to the next option.
4 Print the label by pushing the "Print" button. Make sure there is paper in the device. It may be necessary to press the "Feed" button to align the label within the device. Print as many labels as necessary. To erase the text, simply press the backspace button until the text is gone.
5
Turn off the device by pressing the power button.
Mercedes Custom Parts
Jun 06, 2012 | Brother Office Equipment & Supplies
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I change the name display on the MLX-28D?
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Jan 07, 2010 | Lucent Legend MLX-28D Corded Phone
Need to change the directory of extensions.
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Oct 26, 2009 | Lucent Merlin Legend MLX-20L Phone
How do I change the name that comes up on screen for a given extension?
To administer Labels for Extensions from the System Programming console2.gif:
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
  14. Press Home or Exit to exit programming2.gif mode.
Oct 02, 2009 | Avaya MLX 5D Corded Phone
I need to know how to change the names on the extensions
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Sep 10, 2009 | Avaya 4424D Corded Phone
Need to change extension names on a MLX-20l phone
http://dstech1.com/changing-the-name-on-an-extension/
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Jan 13, 2009 | Lucent Merlin Legend MLX-10D Phone
Lucent MLX-20L Extension Edit
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Group code
I believe what you want is at the bottom of this list.
If you frequently send faxes to the same group of telephone numbers, you can assign these numbers to a group.
Only Speed Dial and One Touch numbers can be assigned to a group. A maximum of 25 Group Numbers (WorkCentre Pro555) / 50 Group Numbers (WorkCentre Pro575) can be assigned (in the range 1-1999). Preset group numbers can also be used for polling.
The following information is included below:
  • Create a new group
  • Add numbers to an existing group
  • Delete numbers from an existing group
  • Delete an existing group
To print the Group Phonebook, see the Related Items below for additional information.
Create a new Group:
  1. From the Standby Mode, press the [Menu] (up arrow) button on the Control Panel, then press [3], [3].
  2. Use the numeric keypad to enter the Group Dial number (1-1999) you want to assign to this group.
  3. Press the [Enter] button. The screen will display a name.
  4. Use the numeric keypad to enter the Group Name (20 characters maximum), then press [Enter].
  5. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, then press [Enter].
    NOTE: The One Touch and Speed Dial numbers must already be programmed. See the Related Items below.
  6. Repeat step 5 to enter additional numbers.
  7. When you have entered each number you want to include in this group, press [Enter].
    NOTE: Group Transmissions are easier if a group is linked to a One Touch button.
  8. To assign this group to a One Touch button, press the One Touch button. To skip this step, press [Enter].
  9. Press the [Exit] or [Stop] button to return to the Standby Mode.
To add numbers to an existing Group:
  4. Press [2] to modify this group.
  5. Use the numeric keypad to enter a new group name, then press [Enter], or press [Enter] to retain the old name.
  6. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, and then press [Enter].
  7. Repeat step 6 to enter additional numbers.
  8. When you have entered each number you want to include in this group, press [Enter].
  9. Press the [Enter] button.
  10. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete numbers from an existing Group:
  6. Press the One Touch button you want to delete from this Group, or enter the Speed Dial number, and then press [Enter].
  7. Press [1] to delete this number.
  8. Press [Enter] to delete the number, or press the [Exit] or [Stop] button to exit without deleting number.
  9. Repeat steps 5 through 7 to delete additional numbers.
  10. When you have deleted each number from this group, press [Enter].
  11. Press [Enter].
  12. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete an existing Group:
  2. Use the numeric keypad to enter the number of the Group you want to delete, then press the [Enter] button.
  3. Press [1] to delete the group number.
  4. Press the [Exit] or [Stop] button to return to the Standby Mode.
elem_1_spacer.gif Related Items:> See AlsoHow To Print and Read the Group Phonebook Report
> See AlsoHow To Modify the Default Resolution and Contrast Settings
> See AlsoHow To Assign / Modify Speed Dials in the Phonebook
Dec 11, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
FAX back
Do you mean to get the paper document back out of the machine? If it doesn't feed out automatically, it may need to be repaired.
If you mean that you want confirmation that a fax was sent, you can turn on the TX (Transmit) REPORT. This will print out the first page of a fax sent successfully.
1. Press the Additional Functions button.
2. Use the arrows to select FAX SETTINGS. Press the Set button.
3. Use the arrows to select REPORT SETTINGS. Press Set.
4. Use the arrows to select TX REPORT. Press Set.
5. Use the arrows to select OUTPUT YES. Press Set.
6. Press the Stop/Reset button.
The machine will automatically print an Activity Report after every 20 faxes (sent or received). If you want an Activity Report at any time:
1. Press the Function button.
2. Press Report button (number 03 on the left side of the keypad)
3. Use the arrows to select ACTIVITY REPORT.
4. Press the Set button.
Apr 17, 2008 | Canon PC-1080F Plain Paper Laser Fax
Sony Ericsson K850i  Mobile Phone Logo
69 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
