Question about Frigidaire ATF6000ES Front Load Washer
Something hitting as drum spins out sound as if something got between drum and wall
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
There could be one of teo things wrong. Your bearing on the back of the drum could be worn out. Or the spider bracket could be broke. You will need to take the machine to see which it is.
Posted on Jun 28, 2009
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
SOUNDS LIKE UN HAVE SOME ITEM OR COIN ETC STUCK BETWEEN THE TUB AND WALL. YOU HAVE TO REMOVE THE TOP PANELS THEN REMOVE RETAINER CLIPS AND REMOVE THE BODY TO ACCESS INSIDE DRUM
Dec 12, 2016 | Kenmore Washing Machines
Sounds like a loose screw on spin cycle
More than likely it's something like a wire from a brasiere, or something from a pocket that has dropped into the drum..
Use a torch, and look through the holes in the drum until you see the object.. then use a thin wire through the holes, to poke it to the front, if you remove the seal, or poke it towards the drain outlet, then clean out the pump filter.
Dec 02, 2014 | Whirlpool Washing Machines
I have whirlpool lsq9110pw2 washing machine. During the spin cycle, there is a clicking sound, and eventually you can smell and see smoke. I have replaced the motor couplings and it still does the same...
When it is spinning open the lid and see if the spinning stops or if it is relational to the spinning of the drum. It sounds like either the clutch is bad or the brake shoes are rubbing or maybe something is stuck between the drum and the tank wall.
Oct 17, 2014 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Jul 30, 2009 | GE WSXH208A Front Load Washer
Something hitting as drum spins dry sounds like
it could be your spider has gone or your bearings have gone.
Jun 27, 2009 | Frigidaire Washing Machines
Washer makes loud scraping sound
Could very well be the pump as well. These pumps have been notoriously bad for the pully shaft housing slipping down and hitting the pump pully. More that likely your problem.
Jul 31, 2008 | Maytag Performa PAV2200
Frigidaire ATF6000ES Front Load Washer Logo
90 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
